also you can have the exclusive
rank
rank
OxtonyxO wrote:with the fuel pump to earth it will run constantly, instead of being controlled by the ecu
normally runs to pressure then stops( when ign on)
then runs again on a signal from cps on trying to start
rover wrote:This is the neatest conversion I've seen yetFantastic work
I'm gona come n find you when its done, seeing as you must be somewhere fairly local to me![]()
Rover.
