cosworth mk2
Re: cosworth mk2
Postby 24v » Sun Apr 19, 2009 10:19 am
Give me a day or so to organise the pic.
Also will I just redrill the rear drums and half shafts aswell?
Can a higher ratio steering box be fitted to make the steering lighter?
If so are they available?
Cosworth mk2 crew cab with IFS
24v
Cosworth Powered
Cosworth Powered
Re: cosworth mk2
Postby Luke » Sun Apr 19, 2009 10:30 am
you've got to be carefull redrilling the rears :!: the brake drum relys on the 160pcd to work and the center hole is very large so if tha goes over the new pcd it wont work :!: to do mine to 112pcd i converted to disks :D
if you can put up with the extra width then adapters on the back is the easy way :D
post a pic of the alloys too :mrgreen:
with the front to make the steering lighter without pas it would also increase the turns lock to lock :(
Re: cosworth mk2
Postby 24v » Sun Apr 19, 2009 10:39 am
Will put up a picture of both.
I dont understand what you mean about lock to lock on the front?
What brackets did you use for mounting the calipers?
As mine looks like a version of an english axle I am going to see if the off the shelf brackets might fit?
24v
Cosworth Powered
Cosworth Powered
Re: cosworth mk2
Postby whitevanman66 » Sun Apr 19, 2009 1:03 pm
lookin good ..i think transits should come with cosworth as standard ....i like the cossie turbo lump (yb) myself ,i think its such a nice lookin lump ..first time ive seen a cossie goin in an older trannie too ..keep the pics comin
whitevanman66
Re: cosworth mk2
Postby Luke » Sun Apr 19, 2009 5:35 pm
24v wrote:I dont understand what you mean about lock to lock on the front?
basically you turn the steering wheel more for the wheels to turn the same - try greasing the king pins and good tyres - even with the V6 it shouldnt be that heavy :)
24v wrote:What brackets did you use for mounting the calipers?
i made the brakets - theres a thread on here in customising section with pics and a guide to how i did it :D
whitevanman66 wrote:first time ive seen a cossie goin in an older trannie too ..
not seen mine then :D
Re: cosworth mk2
Postby AlanN » Sun Apr 19, 2009 5:43 pm
whitevanman66 wrote:lookin good ..i think transits should come with cosworth as standard ....i like the cossie turbo lump (yb) myself ,i think its such a nice lookin lump ..first time ive seen a cossie goin in an older trannie too ..keep the pics comin
Yer!!! Common as muck :lol: :lol: :lol:
I must admit the YB does look better, but the sound out of the back of the V6 is awsome 8) 8) 8)
Re: cosworth mk2
Postby whitevanman66 » Sun Apr 19, 2009 6:10 pm
theres a capri started to show its face lately in pompey,sounds like a rover v8 or chevy big ponies ..that sounds nice too
whitevanman66
Re: cosworth mk2
Postby 24v » Thu Apr 23, 2009 12:09 pm
Hi
still trying to organise photos.
I read the how to on the disc conversion.
What vito discs did you use?what model?
I am going to go this route after seeing the drum.
Might go to Transitmania.
24v
Cosworth Powered
Cosworth Powered
Re: cosworth mk2
Postby 24v » Tue Apr 28, 2009 1:16 pm
24v
Cosworth Powered
Cosworth Powered
Re: cosworth mk2
Postby 24v » Tue Apr 28, 2009 1:20 pm
24v
Cosworth Powered
Cosworth Powered
Re: cosworth mk2
Postby AlanN » Tue Apr 28, 2009 4:54 pm
Keep them pictures coming :D
Re: cosworth mk2
Postby Luke » Tue Apr 28, 2009 5:45 pm
looking good 8) 8) on mine i needed to relocate the coil pack - its right down on the bulkhead and the plenum needs to come off to get at it! - yours must be further forward and mabe a bit lower than mine :D
24v wrote:What vito discs did you use?what model?
cant rememebr tbh but they were 10mm thick i think :? if that helps :lol:
Re: cosworth mk2
Postby neilc5023 » Tue Apr 28, 2009 7:44 pm
looking real good how much were the rims?
neilc5023
Re: cosworth mk2
Postby oldskooler » Wed Apr 29, 2009 9:46 pm
crackin project there keiran. it has to be the first 24v tranny transplant in ireland. your tempting me to become number two!! :mrgreen:
oldskooler
Re: cosworth mk2
Postby 24v » Thu Apr 30, 2009 9:08 am
Thanks Declan
Im hoping to have it ready for Mondello Live.....
Are you going?
24v
Cosworth Powered
Cosworth Powered
