Ordering timing belt and fan belt in the mean time.
Right, I was wondering about the best way to clean off the surface rust on the bottom of the van...
Is it normal to use a pressure steam cleaner to get some layers of dirt and rust off? Or should you only use a drill and a wire brush?
What is the best way to go about this...
Also, once you've exposed all the bare metal on the bottom, what is the best way to treat it so the rust doesn't come back?
Do you first paint over the bare metal, then cover it in something else?
TIA
