think its a 1994Muttley wrote:What year is the axle?
Muttley wrote:That will deffo be metric fine, I thought it was a mk1 axle
no i can just cut the pipe shortMinorMatt wrote:You need a 4 hole one for a domestic take off don‘t you Luke?
yeah basically what i plan to do is convert the tank to pick up off the top by cutting off the pipe that goes to the bottom as the pipe is mounted at the topMinorMatt wrote:Thats correct...
But a gas bottle takes off the vapour at the top, whereas an LPG tank takes the fluid from the bottom!
