MK6 SWB Cosworth YB Conversion!
Re: MK6 SWB Cosworth YB Conversion!
Postby WENNY » Fri May 09, 2008 8:22 pm
pin 25 is the feed, i run coil packs and i ran the rev counter off pin 25, theres also another green wire in the ecu you can use but i cant remember the number, what clocks are you using
350 200PS 3.2 LIMITED LWB
350t 125 RWD MARTINI TRANSIT
WENNY
Postby Luke » Fri May 09, 2008 8:23 pm
Sorted the pas leak - was the joint on the return pipe - didn't have an o ring on - i dont think it was ever ment to :? but it has now :lol:
other than that - cleaned all the crap out of the back - filled it up - all set for tomorrow 8) 8) :twisted: 8)
only thing we do have is a slight water leak from where the sender is fitted (wrong thread) we'll try to sort that tomorrow morning but if not we'll just put up with it :lol:
and never did sort the starter :roll: still held on by 1 bolt :lol:
Postby Luke » Fri May 09, 2008 8:24 pm
WENNY wrote:what clocks are you using
we origanally tried the mondeo and the transit DOHC - neither worked :( but we have the mondeo ones in as they have the temp gauge - which does work :D
Postby WENNY » Fri May 09, 2008 11:30 pm
thing is your trying to run a dizzy engine/rev counter thru coil pack clocks, just put a aftermarket counter in the place of the mondeo one inside the clocks
WENNY
Postby Luke » Mon May 12, 2008 12:25 pm
Made the North weald meet 8) - managed a 17.31 ¼mile time :D not bad but there's plenty scope for improvement :D
didn't get time to try the mk1 mondeo revcounter on :!:
Postby WENNY » Mon May 12, 2008 6:22 pm
what power you running ust standard, plent of scope of getting them times down to 13`s
what was the terminal speed as you crossed the line
my little escort van has ran 11.7 @ 118.5mph at pod
WENNY
Postby Luke » Mon May 12, 2008 6:25 pm
i think the speed across the line was about 85 :|
certanly wants to be faster :lol:
Postby WENNY » Mon May 12, 2008 8:11 pm
ye plenty of scope on them times
WENNY
Postby Gavin » Mon May 12, 2008 9:15 pm
i was thinking about this today running about in my 2.0 pinto efi van, i counted it out on my watch away from the lights and it clocked about 19s @ about 70mph when the odo started to turn from 0.2 to 0.3. and it was fully loaded with several sheets of 18mm 8x4 mdf and plasterdbard, and a stack of carpentry and plastering tools, a 12" double bevel chop saw, and a dozen bags of rubbish from the last job!
not very accurate i'll admit, but still, another 100bhp (150?) from the cossies should surely be worth more than 1.5s and 15mph :?
maybe its just gearing not suiting the engines......i wonder what your overall gearing is in each gear?
is the diesel box different to the petrol one? are the ratios longer to suit the shorter rev range of the diesel? im assuming the donor vans were oil burners as they are far more common.
from the speedo (again not very accurate) mine seems to be
1st 5mph/1000rpm (26mph @ 5250 redline)
2nd 10mph/1000rpm (53mph @ redline)
3rd 15mph/1000rpm (79mph @ redline)
4th 20mph/1000rpm (105mph @ redline) - but realistically it will only do 95 as its screaming its tits off
5th 27mph/1000rpm (142mph @ redline) - have seen 115mph on a few occasions, but realistic indicated max is 100-105 on a flat road.
Gavin
Postby OxtonyxO » Mon May 12, 2008 9:17 pm
i was on the rev limiter in 3rd at 65 had to change to forth on all 3 runs :lol:
OxtonyxO
Postby Luke » Mon May 12, 2008 9:18 pm
this van was built on a petrol and has the gearing from it :D
speaking to stu today he thinks it was down on power and got worse as the day progressed - think it might be loosing pressure from the dump valve as you can now hear is seeping out :!:
Postby Gavin » Mon May 12, 2008 9:27 pm
Luke wrote:this van was built on a petrol and has the gearing from it :D
what about the mk2?
tonys experience seems to bear out what im saying, 65 in third just seems far too short, especially for a v6. if the wheel spin in first isnt adding seconds, the extra gearchange must be!
Gavin
Postby Luke » Mon May 12, 2008 9:34 pm
what about the mk2?
same :D proper petrol V6 box and a 4.11 diff it was going into 4th before the line too - without a doubt getting the power down was the problem with that one :D
Postby Gavin » Mon May 12, 2008 10:00 pm
strange, either my observations are way out (like 25% out) or the 2.0 efi petrol set up is very different to the diesel or the v6 set ups.
i dont think my van reads that far out, at an indicated 70mph im usually in the outside lane passing most things, and at 100 only the odd car goes past....not really any different from any of my cars or bikes.
Gavin
Postby OxtonyxO » Mon May 12, 2008 10:02 pm
oh yeah my speedo reads 10 mph too fast
OxtonyxO
