The cube rebuild
Re: The cube rebuild
Postby hitman » Fri Dec 14, 2007 9:44 pm
need some advise,insperation :roll: got the cube all set up for the rover lump but got to rebuild the engine an sort lots ov bits for the engine an box,however :roll: ive got a granada cosworth comin into my possesion tmoro,what do i do,Image
hitman
Postby OxtonyxO » Fri Dec 14, 2007 9:59 pm
oh thats a tough one but then im biased to the cosworth and i think you would get better mpg from the v6?
OxtonyxO
Postby madmark » Sat Dec 15, 2007 6:33 am
:shock: oh that is a tough one but the sound of the 8 pot will do it for me! :mrgreen: :mrgreen:
Postby Luke » Sat Dec 15, 2007 6:13 pm
tricky one :lol:
the biggest hassle with the cossy is the adapter plate to get it manual if its auto then it would be easier :D
but having just come back in from a spin round the block in my cossy spinning the wheels in 3rd :mrgreen: im very happy with it :lol:
problem is if you did go cosworth, then i'd have the 2nd fastest cossy transit in sheffield :| :lol:
Postby andykay » Sat Dec 15, 2007 6:23 pm
What you should do is fit the cossy engine in my mk4 and with the cash you make out of the job have the v8 rebuilt and all polished and painted then put it in the cube :D
Andy.
1992 MK4 120 SWB V6 24V AUTO
1996 MK5 100 LWB TD AUTO
Don't take life too seriously; you'll never get out of it alive.
andykay
Cosworth Powered
Cosworth Powered
Postby madmark » Sat Dec 15, 2007 7:04 pm
andykay wrote:What you should do is fit the cossy engine in my mk4 and with the cash you make out of the job have the v8 rebuilt and all polished and painted then put it in the cube :D
Andy.
:lol: :lol: :lol: :lol:
Postby hitman » Fri Dec 21, 2007 6:52 pm
got it runnin an its sweet as,if i decide against using it it will be for sale :D
hitman
Postby Guy88 » Fri Dec 21, 2007 6:54 pm
thats a BOB engine and it has PATS :(
to make it easier you can use the earlier loom and ECU
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby dangeeeeerousss » Fri Dec 21, 2007 7:01 pm
hi hitman
stick with the 8 m8
ive not managed to catch that guy in yet with the parts he works odd hours...im gonna try him in the morning because i do know he has the odd weekend off
what bits do you need for your rebuild....
dangeeeeerousss
Postby hitman » Fri Dec 21, 2007 7:05 pm
Guy88 wrote:thats a BOB engine and it has PATS :(
cheers guy88, read that they are a bit tricky :?got a mate whos s**t hot with electrics,but ive got two more in the pipeline an they are the early ones :wink:so still undecided :|
hitman
Postby hitman » Fri Dec 21, 2007 7:10 pm
just thought mite stick
into
with a couple ov turbos,once id picked lukes brains that is :mrgreen:
hitman
Postby OxtonyxO » Fri Dec 21, 2007 11:10 pm
if you use the bob engine your going to need a boa loom with an rpm switch for the vis intake, or use mega squirt
if you are turboing then mega squirt or emerald is the way to go anyway as the standard ecu cant handle the extra air or retard the ignition :?
OxtonyxO
Postby hitman » Fri Dec 21, 2007 11:45 pm
OxtonyxO wrote:if you use the bob engine your going to need a boa loom with an rpm switch for the vis intake, or use mega squirt
cheers for the info pal :D think i will be contacting u if i decide to turbo it for ur help :wink: ,have u used emerald :?:
hitman
Postby hitman » Fri Mar 21, 2008 12:12 am
not much ov an update :roll: but stripped the v8 down to rebuild it last night, cleaned an painted g,box tnight,on with weldin front end this weekend :D oh an i weighed the cossy ultima in :evil:
hitman
Postby hitman » Thu Apr 10, 2008 11:08 pm
front end welded,bulkhead cut welded an shaped up for v8, under front arches under sealed(not pretty but solid),front suspension rebuilt and refitted :wink:
hitman
