The 'Cossybus'-updates!
Re: The 'Cossybus'-updates!
Postby rover » Wed Apr 09, 2008 8:12 pm
neo1 wrote:Fuel pump will flatten battery quick if ign left on, for any lenth of time, also if in a crash or in the event of fuel leakage system will just pump the tank dry, could be very iffy to be honest.
I agree.
Obviously I'm not up on the wiring of these but most injection pumps only run for about 1-2 secs on ignition, then start up again on cranking, not really safe to run it permantly.
Next time I know I'm going to be in your neck of the woods MantaV8 I'll give you a shout , probably one day next week :D
Rover.
rover
Postby mantav8 » Wed Apr 09, 2008 8:21 pm
I agree.
Rover.
Thanks for the advice guys,I'll snip the ecu wire and plumb it iin there then no loss LOL!
Rover,should have been this week mate as Iv'e been off work! :mrgreen:
mantav8
Cosworth Powered
Cosworth Powered
Postby rover » Wed Apr 09, 2008 8:26 pm
If I can coax a job out that way for tomorrow I will :D
Rover.
rover
Postby Guy88 » Wed Apr 09, 2008 8:28 pm
Mine ran permanently with an inertia switch fitted
For the VSS it needs it for the auto :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby mantav8 » Wed Apr 09, 2008 8:29 pm
rover wrote:If I can coax a job out that way for tomorrow I will :D
Rover.
YHPM! :wink:
mantav8
Cosworth Powered
Cosworth Powered
Postby mantav8 » Wed Apr 09, 2008 8:32 pm
Guy88 wrote:Mine ran permanently with an inertia switch fitted
Cheers Guy!-I'll suss the speedo first and look at wiring this in!
Was it you who told me the ignition live was the white plug near the servo?-just wondered if the green with it was for a Tacho,I might fit an aftermarket one and I take it this will drive it?
:wink:
mantav8
Cosworth Powered
Cosworth Powered
Postby sidspop » Wed Apr 09, 2008 9:26 pm
If I remember rightly Sierras used to have an inertia switch in the boot floor, under the spare wheel. I found out one day when I hit a speed bump hard, and the car stopped. Took me ages to find it.
Remember, safety first.
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Postby custom » Wed Apr 09, 2008 9:32 pm
my fuel pump runs permantly and never had a problem with it its fine and doesnt drain the battery at all
custom
Postby rover » Thu Apr 10, 2008 9:06 am
custom wrote:my fuel pump runs permantly and never had a problem with it its fine and doesnt drain the battery at all
Maybe not but if you have a prang the fuel will flow until either the tank's empty or the FIRE burns the wiring out :roll: Its not just for YOUR safety, think about OTHER road users :!:
In theory it SHOULD have an inertia switch as well as being relay controlled.
Rover.
rover
Postby mantav8 » Thu Apr 10, 2008 5:49 pm
Good to meet you today Rover! :wink:
Got the exhaust done,not exactly a PowerFlow I know but gets me mobile!
Had to fetch a petrol prop today so I could loose the 'Doughnut' on the scorpio prop,going tomorrow to be shortened.
Silly question but how do you count the pins on the ECU?
I can see 1,11 and 20-does it start again to the left,i.e next row is 21,22 etc? :?
mantav8
Cosworth Powered
Cosworth Powered
Postby rover » Thu Apr 10, 2008 6:19 pm
If the exhaust fits and does the job what more could you ask?
Good to meet you too mate :D
Hopefully we'll get to see it at a meet before your 'other' plans take place :mrgreen:
Rover.
rover
Postby OxtonyxO » Thu Apr 10, 2008 7:03 pm
the pins have have the numbers on them :wink:
OxtonyxO
Postby mantav8 » Thu Apr 10, 2008 8:17 pm
OxtonyxO wrote:the pins have have the numbers on them :wink:
Cheers Tony but my eyes are shot! (age!)-there isn't a diagram anywhere is there? :wink:
mantav8
Cosworth Powered
Cosworth Powered
Postby Luke » Thu Apr 10, 2008 9:48 pm
the numbers are on the plug :D
but looking at the ecu with the notches at the top
top row 41-60
middle row 21-40
btm row 1-20
have you seen this post :?: viewtopic.php?f=13&t=26266
oh and great progress 8)
Postby mantav8 » Thu Apr 10, 2008 10:05 pm
top row 41-60
middle row 21-40
btm row 1-20
LOL!-I have mate and if you can see the numbers/pins etc. then your better than me!!
mantav8
Cosworth Powered
Cosworth Powered
