tonys smiley swb 80 cosworth v6
Postby OxtonyxO » Thu Jan 18, 2007 8:37 pm
right i have a problem with the fuel supply
i think i have a way round it but just want some opinions
i have a cossie fuel pump below and need to connect this to the fuel tank
the feed to the pump is 15mm what i was thinking of doing was to cut the old pick up out of the fuel sender unit and braze in some 15mm copper pipe then use some rubber fuel hose to connect them :D
does everyone think this will work?
also will the pump be man enough to suck the fuel up? or will it need to be gravity feed
here is the pump
http://i45.photobucket.com/albums/f76/O ... 0096-1.jpg
OxtonyxO
Postby Guy88 » Thu Jan 18, 2007 9:37 pm
It will suck it BUT if its higher than the fuel level it will end up being run dry, wearing it out and getting air in :(
I have on mine a Low pressure pump to my swirl pot then gravity to the EFI pump 8)
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Thu Jan 18, 2007 9:40 pm
thats prolly what i'll need to do (swirl pot)- guy what is the make/model of your low pressure pump :?:
Postby Guy88 » Thu Jan 18, 2007 9:50 pm
Cant remember the make. i got it for £55 locally :D
this is the swirl pot. just needs a bigger output :roll:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby rover » Thu Jan 18, 2007 9:59 pm
It would probably be cheaper to get a Facet pump and refulator, then you wont have to mess with the tank at all, bung in your swirl pot under the bonnet and you dont even need a return pipe :D
Rover.
rover
Postby OxtonyxO » Thu Jan 18, 2007 10:10 pm
i was looking at the sierra cossie set up
it runs with a take off from the bottom of the tank
so i could run the pump with an output from the swirl in the bottom of the tranny tank
just need i copper connector 15mm then drill a hole in the bottom of the tank
maybe :?:
OxtonyxO
Postby bj928 » Thu Jan 18, 2007 10:42 pm
the swirl pot is a good idea but i've never run one, but if you go round corners with low fuel it does tend to cut out so it is a good idea to stop that, as for pump,
as for pumps, i've always just used an old 2.8i capri/granada or what ever, even an old xr3i pump would do, old granadas had i little frame with the pump and a filter mounted, they work fine, you can put the pump anywhere, i've even had the pump mounted on the inner wing, on a capri i did once i even put the pump in front of the rad, if you can get a capri one with the bango's and a bit of pipe still attached, normal (reinforced) fuel pipe goes over original pipes with a couple of small jubilee clips, job sorted, its a lot cheaper than going get special pumps and stuff.
bj928
Postby OxtonyxO » Sun Jan 28, 2007 5:25 pm
hurrraaay
i got my fan off :D
also droped the fuel tank today :D
just a thought but has anyone tried to fit the sender unit from the granny to the di tank they look the same 8)
can any one tell me which way round the pipes one the di sender unit are one is bigger than the other
just waiting for my :-
swirl pot
fuel lines
fuel pump
batt cable
batt terminals
batt tray (petrol)
fuse box
relay box
and rad dohc
then im away and running fingers crossed
swirl pot
facet red
fuel lines
and batt tray
all arrived today ,will be busy this week end :D
OxtonyxO
Postby OxtonyxO » Fri Feb 02, 2007 9:29 am
finished the loom last night with the help of luke :D (thanks luke)
here is a pic of the loom with my new batt cable
OxtonyxO
Postby AlanN » Sat Feb 03, 2007 11:25 am
OxtonyxO wrote:finished the loom last night with the help of luke :D (thanks luke)
Ive seen something similar to that in the sweetshop!!!! :shock: :D
Postby OxtonyxO » Sat Feb 03, 2007 5:56 pm
got the second batt in
set out the loom
tidied up some loose ends
OxtonyxO
Postby Luke » Sat Feb 03, 2007 6:12 pm
8) nice one tony, well done mate :D - looking like we'll be getting some of these 24v trannys on the road some day soon :shock: :lol:
Postby Guy88 » Sat Feb 03, 2007 6:17 pm
Looking well
Same swirl pot as me :shock:
Wheres that bit of copper pipe go to :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby OxtonyxO » Sat Feb 03, 2007 6:32 pm
goes to the oil cooler 8)
OxtonyxO
Postby Guy88 » Sat Feb 03, 2007 8:17 pm
OxtonyxO wrote:goes to the oil cooler 8)
How did you do the heater in the end :?:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
