OxtonyxO wrote:Mine was stalling when i was driving it due to the vss not being connected
Have you checked all the hoses for an air leak, as this can cause it to run rough due to unmetered air getting in.
i found two small pipe stubs on the side of the throttle that needed blanking off
if its stalling at idle then check all the connections to the iscv and hoses
OxtonyxO wrote:well i never new that!!
http://fordpower.org.uk/forum/index.php ... c=4985&hl=
have to remember that when i start mine tomorrow !!
never had any problems the first time
MrMPuk wrote:OxtonyxO wrote:well i never new that!!
You have to be a member to read anything on Ford Power.
fordpower wrote:Needs to be driven to re learn the ecu, if I remember right, start up hold a 1000rpm for a min then hold a 2000 rpm for a min then drive at least 5 miles mixed driving.
Mixture is none adjustable as is done by lambas/ecu
madmark wrote::shock: wow mate this is very impresive !
