AndyG wrote:The sooner all that wiring is sending back the correct info to the ECUs, the sooner that engine will be out of "limp Home Mode"![]()
Luke wrote:been working through odd jobs for the MOT, done the new prop centre bearing, speedo's working now too![]()
slowly transferring the functions over to the previa sticks, got the indicators sorted, lights should be easy too but as the previa sticks are low current (not like the transit ones) i need to run everything through relays, i havent got a drawing for the previa ones and i can only find 1 wire out for the main beam - not sure if that can be right as it would mean i can it so the main beam flash works when you pull the stick back but it'd also come on when you push it forwardbit more testing with the meter i think
AndyG wrote:Luke can have it A framed up to you tomorrow if you like![]()
ake wrote:Yes, side lights must work with ignition off.
Luke wrote:still progressing on this - i think i have the sticking brakes sorted now but i really need to get it MOT'd then i can test it out fully![]()
I never wired in the kickdown (needed a switch mounting)- and when i was at north weald i didnt bother pressing it as i had too many other issues, ive been testing it and it does seem to make a noticable difference when its pressedso thats a job thats moved up the list
i also trial fitted the rotating passangers double seat yesterday, it seems to work ok - it will only rotate 90deg but enough to get access to the back of the van - sort of a compromise between having 2/3 seats up front![]()
going to try for the MOT in the week
