Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Re: Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Postby AlanN » Sun Jul 08, 2012 9:04 am
I used to like wiring, but Ive quickly gone off it of late, good luck with that
Postby AndyG » Sun Jul 08, 2012 2:23 pm
The sooner all that wiring is sending back the correct info to the ECUs, the sooner that engine will be out of "limp Home Mode" :!: :wink: :lol:
Postby IgorVigor » Sun Jul 08, 2012 2:37 pm
AndyG wrote:The sooner all that wiring is sending back the correct info to the ECUs, the sooner that engine will be out of "limp Home Mode" :!: :wink: :lol:
all the more reason why I LOVE mechanically controlled engines :lol:
It should be nice when its finished though Luke.....
IgorVigor
Postby Luke » Sun Jul 08, 2012 7:12 pm
well i've done away with the origanal black fuse box - only 3 relays 5 fuses needed in it and they are all on trailing leads so i can transfer them into a new fuse box i've got when i get it positioned :D
the white fuse box i didn't think i'd need so i uplugged it - tested it and it wouldnt start :roll: so i'm going to have to work through it all and see which parts i need :x
i have found 3 wires from the previa stalks so i can have a seperate flash and main beam :D
Postby ake » Sun Jul 08, 2012 8:23 pm
Luke wrote:been working through odd jobs for the MOT, done the new prop centre bearing, speedo's working now too :D
slowly transferring the functions over to the previa sticks, got the indicators sorted, lights should be easy too but as the previa sticks are low current (not like the transit ones) i need to run everything through relays, i havent got a drawing for the previa ones and i can only find 1 wire out for the main beam - not sure if that can be right as it would mean i can it so the main beam flash works when you pull the stick back but it'd also come on when you push it forward :? bit more testing with the meter i think :lol:
The wiring is my favourite bit of any conversion, not done any for a long time, but one day i'll get something to play with
Postby AndyG » Sun Jul 08, 2012 9:34 pm
Luke can have it A framed up to you tomorrow if you like :!: :shock: :lol:
Postby Luke » Sun Jul 08, 2012 9:45 pm
AndyG wrote:Luke can have it A framed up to you tomorrow if you like :!: :shock: :lol:
:lol: :lol:
drawn this up for the lights (this is attempt 1)- is there a simpler way :?: can i get 1 relay that does the lot :? also i dont like the way relays would still be powered up when the keys out
ignore the feeds the ign to the light switch would have to be perm live and the others wrong too.
whats the law on lights for the MOT do i need the sidelights to come on when the keys off is that all i need to do :?
Postby Guy88 » Sun Jul 08, 2012 11:46 pm
how about a trailer relay, that has facilities for 7 functions
failing that how about fitting a relay box from a granada or similar
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby ake » Mon Jul 09, 2012 6:49 am
Yes, side lights must work with ignition off.
Postby IgorVigor » Mon Jul 09, 2012 7:54 am
ake wrote:Yes, side lights must work with ignition off.
Its still to do with parking on a road at night isnt it?
Something like if its a 40mph or higher limit, then you need to leave the sidelights on :S
IgorVigor
Postby Luke » Sun Jul 29, 2012 10:04 am
still progressing on this - i think i have the sticking brakes sorted now but i really need to get it MOT'd then i can test it out fully :)
I never wired in the kickdown (needed a switch mounting)- and when i was at north weald i didnt bother pressing it as i had too many other issues, ive been testing it and it does seem to make a noticable difference when its pressed :? so thats a job thats moved up the list :lol:
i also trial fitted the rotating passangers double seat yesterday, it seems to work ok - it will only rotate 90deg but enough to get access to the back of the van - sort of a compromise between having 2/3 seats up front :D
going to try for the MOT in the week :D
Postby AlanN » Sun Jul 29, 2012 4:46 pm
Good to see you gradually getting there, Ive got a list as long as my arm, but I havent done any of it yet, keep finding other things that peak my interest :roll:
Postby Luke » Sun Jul 29, 2012 10:09 pm
yeah slowly does it :lol:
spent all day fitting the rotating passangers seat and it just fits in :D i didnt help it by moving the drivers seat towards the middle of the van - i dont like vehicles where the seat isnt in line with the steering wheel so i moved my seat to be in line :) anyway the passangers double is back in but this time rotates 8)
Postby robbie.cee » Sun Jul 29, 2012 11:20 pm
Luke wrote:still progressing on this - i think i have the sticking brakes sorted now but i really need to get it MOT'd then i can test it out fully :)
ooh any pics of rotator for passengers seats mate? wicked idea! 8)
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Luke » Mon Jul 30, 2012 8:07 pm
i'll sort a video clip out rob :D
in other news................................. :mrgreen: MOT PASSED TODAY 8) 8) 8) 8) 8)
