Shedrool83's mk6 90 350
Postby shedrool83 » Sun Jun 17, 2012 7:13 am
Bought my first van a few weeks ago.
Its a 90 350 lwb
133k
Since i bought it i have
changed the vac pump
fitted new aux belt and tensioner
new oil filter and oil
new fuel filter
new air filter
reverse camera
recovery beacon
rear work lights
Shelved the back
Sorted the central locking
fitted fuel filler flap
Still want to
Fit towbar
fit nudge bar and front spotlights
fit oem foglights
fit mk7 wheel trims
fit mk7 side repeaters
fit mk7 rear lights
get some kind of decals made up to break up the white on the sides.
Few pics of the vans for sale ad
Few of the work i have done
Still a few things to add in the back for it to be how i want it for work but its more or less there.
I've been thinking about making the front cab a bit more comfy/nice anyone any pics of theres or ideas?
shedrool83
Re: Shedrool83's mk6 90 350
Postby shedrool83 » Mon Jun 18, 2012 7:16 pm
Fit a set of 16" Mondeo wheel trims today and a towbar yesterday :D
shedrool83
Postby shedrool83 » Sat Jun 30, 2012 5:42 pm
Fitted a pair of sparco reclining bucket seats
and mk7 rear lights
shedrool83
Postby Rumble bee » Sun Jul 01, 2012 10:50 am
Hey good job on the van!
Any pics of how you mounted the seats and seatbelts?
Ive got some focus st recaros waiting to go mine.
Cheers
Chris.
Rumble bee
Postby shedrool83 » Sun Jul 01, 2012 6:22 pm
Dont have pics but all i did was bolt a 300m long bit of angle iron to the oem seat base using the original fixing points.Then bolted o bit of angle iron to the seats stuck the seat on to the base and bolted the to bits of angle iron together.
I may of got lucky with my seats being sparco as the two bits of iron meet perfect when i lowered the seat onto the base other makes will more than likely have different fixing points on the seat.
I did it that way instead of welding the iron into place so i can go back the oem by removing four bolts on each seat.
shedrool83
Postby Rumble bee » Sun Jul 01, 2012 7:10 pm
Cheers, gives me ideas.
Rumble bee
Postby DMTL » Mon Jul 02, 2012 9:44 pm
shedrool83 wrote:Fitted a pair of sparco reclining bucket seats
and mk7 rear lights
hiya mate, did the drivers seat go straight onto the standard subframe ?
DMTL
Postby shedrool83 » Tue Jul 03, 2012 7:26 am
Not quite .I'll get some pics of how i did it tonight for you.
shedrool83
Postby shedrool83 » Wed Jul 04, 2012 7:57 pm
Still need to remove the seats again and tidy/paint the brackets but heres a couple of pipes if anyone is interested.
I used another driver seat base to do the passengers which fitted right in place of the bench
shedrool83
Postby shedrool83 » Wed Jul 04, 2012 8:02 pm
Tonight i removed the egr and inlet ,cleaned both out and fitted new gaskets .Just need to make a blank and hopefully i notice a difference.
Also fitted a new side door handle as it was a nightmare to open sometimes but its all good now :D
shedrool83
Postby noah » Thu Jul 26, 2012 9:17 pm
coming on nicely
noah
Postby transitandy » Thu Jul 26, 2012 9:28 pm
noah wrote:coming on nicely
x2 :)
Postby Timmos » Thu Sep 06, 2012 7:30 pm
shedrool83 wrote:Tonight i removed the egr and inlet ,cleaned both out and fitted new gaskets .Just need to make a blank and hopefully i notice a difference.
Good job fella!!
Any chance of a how to on blanking the EGR valve.
Thnaks Tim
Timmos
Postby shedrool83 » Fri Sep 14, 2012 7:58 pm
Good job fella!!
Thnaks Tim
Do a search on here bud thats where i got it from.
shedrool83
Postby shedrool83 » Fri Sep 14, 2012 8:05 pm
Had a spare 2 hours , scorpion backbox welder and a grinder and 2 hours later had this sticking out from under my bumper.
No sound difference but its shiny :lol:
shedrool83
