Lee J's Mk6 - it's long but worth a read.
Postby Lee J » Tue Mar 20, 2007 1:05 pm
Time for a layout change. This is a very rough diagram of how my van looks now:
The blue bit is the load space I use. This is always the same. I already fitted 2 truck/coach seats behind the drivers/pass seats to accomadate the other two members of my crew. So i got to thinking I would like to fit a bed for me when I've just driven 6 hours after a 13hour shift and need to sleep for a while. I also would like to ply line it all out. So I set about it last weekend and just for you lucky people I took some photos.
Please bear in mind I aint a joiner or anything like that so some of my methods may be wrong to those more knowlegable than me. Also some of my references to the van parts may be not correct but you'll get the picture.
This is my plan...
So I got my Black n Decker jigsaw out, van load of ply wood and away I went...
1. Knocked down the old chipboard partition. Noticed how big these vans actually are when you can see one end to the other.
2. Started by bolt a piece of 2x1 across the width of the van, then 4 uprights then topped it off with another 2x1 across the width again and using 'L' brackets, attached the whole thing to the side of the van.
3. I then did the same again but upside down from the roof, about 2' 3" further back. This was all carefully measured so the two cross pieces lined up facing each other...
4. Then I fit some 2x1 pieces to attached these two together. As this was going to form the base of my bed I used thicker/longer alen key bolts.
Finally I put in place two 2x1 supports coming from the under side to the floor, positioned at the rear to support my weight and stop me ending up in with the load during the night.
This is looking from the load area towards the front...
...and this is from the second row of seats towards the back..
5. Now was a good time for a brew and I sat for 10 minutes contenplating my next move.
ten minutes later...
I cut out the correct shape of ply wood to do the front panel. Im using 6mm ply for all the panelling and 15mm ply for the base of the bed.
I offered it up, double checked the fitting, made a couple of adjustments then with the nail gun, nailed that sucker to the framework. BANG BANG BANG BANG, neighbours are well impressed at this point. One or two curtains twitching.
I did the same for the back of the bottom section and the back of the top section, then I fit the base of the bed. Finally I fit the front of the top section. Just a note: In between the panels I used some loft insullation.
6. Today I will atempt to ply line the rear load area. I carefully measure up, then measure up again, and then have a brew and finally check that measuring again. The jigsaw is revved up and away I go. whoa! this is fun!
success! it fits like a glove.
:idea: try it for size on the other side... yep it fits this side too... lay it down on a new piece of ply and transfer the image. Cut it out and I now have both sides perfecto fit! I used self tapping screws with these panels. 4 across the middle then 3 across the top. look see...
7. I want a shelf up near the top, to store overnight bags and a few smaller items. I screw a 2x1 baton across the top section of the partition and place the 15mm ply shelf (i've already cut) on top. I use spirit levels to get the shelf perfect then mark it.
Next job is a ball acher. I have to put another cross piece of 2x1 from one side of the van to the other, to support the front of the shelf. This is done by cutting a small 2x1 rectangler hole in my newly fitted ply sides. I do this perfectly and fit the 2x1 across. The shelf is nail gunned down. BANG BANG BANG BANG... neighbours hate me now.
8. Using office carpet tiles from Focus DIY (£1.98 per tile) I carpet tiled the whole of the load area.
That should be the load area finished. What do ya reckon to that then?
9. Time to carpet the partition in the cabin. Im using car carpet, £6 a roll from my local motor spares shop.
Also using a felt fabric I covered the roof throughout the van and the sleeping area too.
I have carpeted the back panel and I have got a materess from a caravan thats only 2' 2" wide that fits perfectly. I will be fitting a curtain and the matteress tonight so I will post again tmrw with finished pictures of the whole thing.
Thanks for reading.
Transit Van - Gonna cost me a marriage if I'm not careful.
Lee J
Postby MrMPuk » Tue Mar 20, 2007 1:16 pm
Is there ment to be pictures?
Postby Lee J » Tue Mar 20, 2007 1:41 pm
yep, i see them. anyone else not see them?
Lee J
Postby chadmat » Tue Mar 20, 2007 2:02 pm
Looking at pictures, looking good mate!
8)
In a MK6 280 SWB semi hi!!!!
There you go! At last!
chadmat
Postby rover » Tue Mar 20, 2007 2:05 pm
I see them, and what a cracking job you've made of it :D Very nice mate 8)
Rover.
rover
Postby Lee J » Tue Mar 20, 2007 2:30 pm
cheers guys, first time i've done anything like this.
ta
Lee J
Postby Altransit » Tue Mar 20, 2007 2:58 pm
I can see them, mate :wink:
Very nice job BTW 8)
Postby BigNeil » Tue Mar 20, 2007 4:04 pm
looking great and you say you are not a joiner ?
superb, I am not a joiner either and I would definetly not manage that in fact at some stage I will post a picture of my joinery for all to laugh at/give constructive advice/comment
:) :D
BigNeil
Postby jimmyjoiner » Tue Mar 20, 2007 6:52 pm
First class mate!!! I'd give you a job tommorrow (if I I had one going) :lol:
If it's got tits or wheels...you'll have trouble with it!!
jimmyjoiner
Postby Luke » Tue Mar 20, 2007 7:59 pm
Great work mate and great write up 8) top marks :D
im gonna copy some of your ideas when i do mine :lol:
Postby mrgasoil » Tue Mar 20, 2007 8:20 pm
proper job mate :wink: well done :D :D
mk5 flareside with tail-lift GONE and will be missed!
Mk6 T350 LWB DRW dropside with tail-lift.
mrgasoil
Postby MarkM » Tue Mar 20, 2007 9:10 pm
Looks nice and neat. Although not a joiner myself I have looked several times at the skeleton view of all the struts etc and I keep coming back to the two rear supports. They look way too thin to be a long term support and also vunerable to being broken from whatever you store in the rear moving. Do you have any plans to strengthen these supports?
MarkM
Postby Lee J » Wed Mar 21, 2007 10:27 am
MarkM wrote:Looks nice and neat. Although not a joiner myself I have looked several times at the skeleton view of all the struts etc and I keep coming back to the two rear supports. They look way too thin to be a long term support and also vunerable to being broken from whatever you store in the rear moving. Do you have any plans to strengthen these supports?
The supports are 2x1 timber, the load in the back never moves but I see what your saying. I plan to replace these 2 supporting legs with some light weight steel (you know, the stuff that has an 'L' profile) or some steel box section.
cheers for your concern.
Lee J
Postby Lee J » Fri Mar 23, 2007 1:43 pm
another couple, now it's finished. Not very clear as it was dark outside but I'll take some more this weekend and post them on monday.
Lee J
Postby Lee J » Mon Mar 26, 2007 1:17 pm
here's the girl...
Here you can see I have fitted lower (under the bumper) Ford foglights. I put these on a switch. Simple on/off.
I also have the spots in front of the grille, these are wired to the main beam.
On the roof at the front are 2x clear marker lights, wired to the side lights.
Same on the back but 2x red marker lights. Those JCB worklights are wired to a switch for on/off use.
Here's my switches... chrome with red LED ends.
(L to R)
SAT Nav. Hard wired.
Front Fogs
Rear worklights
Lee J
