... without choke.
Hi Folks,
I've got a 2l pinto with a weber 34 ich fitted to my mk2 swb motorhome.
Starts fine, engine purrs nicely but it hesitates on acceleration with choke fully in. Give it a smidge of choke and it pulls ok. Cruises ok without choke.
Also I'm only getting 12mpg!
I've done the seals on the servo and renewed all vac hoses. Distributor vac is good. So is oil breather. Checked for air leaks on manifold etc. Timing set to 8°.
New jets (165 main, 50 idle, 190 air
corrector), diaphragm, float and gaskets on carb. Compression is good.
Any ideas what's going on?
Not looking for stella mpg but 12's a bit low!
Any ideas?
