2.5 DI timing belt, remove crankshaft pulley?
Postby peteMK2C » Sun Feb 25, 2024 1:55 pm
Hello everyone,
I have to change the timing belt again.
The last time, 8 years ago, I removed the pulley from the crankshaft. To do this, you have to loosen the 36 mm bolt (330 nm tightening torque).
Now I wanna ask if anyone in the forum has fitted the timing belt to an MK2 with a 2.5DI diesel engine without removing the pulley.
Last time I was worried about having to bend the new timing belt too much to get it round the corner of the oil pump housing.
Here are a few pictures from the last time when I did the timing belt so you can see what I mean:
Do you guys always remove the pulley when doing the timing belt :?:
Ii's just that I don't want to damage the new timing belt right away during installation.
Thanks,
Pete
peteMK2C
Re: 2.5 DI timing belt, remove crankshaft pulley?
Postby dumper » Sun Feb 25, 2024 8:16 pm
Long time ago but I don’t remember removing the pulley
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby peteMK2C » Mon Feb 26, 2024 4:39 pm
Thanks for replying dumper!
So you managed it to get the belt around that corner.
I'm currently trying to figure out if the housing of the oil pump had changed during that early development of the DI from 1985 to 1986
It's not so easy to find out cos when I'm doing some image search on that subject I rarely get any usable pictures.
From the picture I have seen so far, there might have been a change... some sort of flattening of the cover near the pulley which would sure make the belt change easier.
peteMK2C
Postby dumper » Mon Feb 26, 2024 6:53 pm
Due to the high torque of the bolt never try to remove them onlytime was when rebuilding the engine or oil seal it must be over 30 years since I did a mk2 but I think you just had to be careful getting it in
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Muttley » Mon Feb 26, 2024 10:51 pm
I have done Mk2 di belts without removing pulley, there is a bit of feeding through of the belt but it does go through.
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby peteMK2C » Tue Feb 27, 2024 8:24 am
Thanks Muttley!
I think I'll just try getting the old timimg belt out through that gap and if that is too much of a struggle I'll remove the pulley again.
Last time when I did the belt change I had removed the crankshaft Bolt and the pulley. We blocked the engine by putting in the second gear and applying the handbrake. After the change we put the bold back on with 330 nm
With the right tools it is usually no trouble removing the pulley, given that there is not much corrosion around there.
I have a hynes manual now, which I didn't had back in 2016. In the Haynes the timing belt change is described without removing the crankshaft pulley. Crankshaft pulley removal in the Hynes manual in deed comes up only when doing the front oil seal or the oil pump.
OK, the Hynes is for MK3 Diesel from 1986 onwards but the 86 engine should be very close to the 85.
peteMK2C
Postby dumper » Wed Feb 28, 2024 7:14 am
Yes that’s how a got them off back in the day as a 1/2 drive air gun wouldn’t work unlike today’s battery guns have so much more power
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Muttley » Wed Feb 28, 2024 10:39 pm
Quite right Dumper, my Milwaukee M18 make light work of crank bolts.
Muttley
Return to Mk 1 & 2
