Front Brake Retracting Springs
Postby mickey boy g » Mon Mar 04, 2024 3:11 pm
Hello gang. I've just changed the cylinders and shoes on both front brakes (see photo). The nearside wheel is now stiff and looks like the new cylinders are too strong for the old springs so they are not doing their job and retracting the shoes from the drum.
Anyone have any new retracting springs, or have a link for a company etc that will have?
mickey boy g
Re: Front Brake Retracting Springs
Postby Ralph.9 » Tue Mar 05, 2024 8:20 am
Lee at Batchelors Ford Spares has all my stock of new brake springs.
Ralph.9
Postby mickey boy g » Tue Mar 05, 2024 11:02 am
Thanks Ralph, I have contacted Lee about them.
mickey boy g
Postby mickey boy g » Sun Mar 10, 2024 5:07 pm
I've had no luck finding any of these yet. Any suggestions will be very gratefully received.
mickey boy g
Postby Mr twin choke » Wed Mar 20, 2024 9:10 pm
Have you tried the swapping the springs over from the side that turns freely to see if the fault goes away? The springs in your picture aren't stretched and look fine visually. At least that would confirm that the springs are indeed causing the problem. Also, have you replaced the flexi hoses? They can start to break up on the inside with age and cause binding brakes as they won't allow the pistons in the cylinders to retract properly.
Mr twin choke
Postby greek » Fri Mar 29, 2024 7:09 pm
Yep had same problem warm front brake thought it was springs but new flexi brake pipe cured the problem.
I`m to old to lie under Transits
greek
Postby mickey boy g » Wed May 15, 2024 11:51 am
Good idea. I'll try replacing the flexi pipes while I'm at it.
New conundrum is that the servo unit is probably leaky. Swapped out all the seals from the master cylinder and now the pedals a farting squishy mess. I've removed the servo (after I tested it), seems to have a small leak, probably the diaphragm.
Anyone have any idea what the part number is for these servo units? Cannot find one stamped on it anywhere.
An internet worm hole beckons...
mickey boy g
Postby greek » Thu May 16, 2024 1:08 pm
just replaced the servo on my Mk1 Mickey looked a while never found one but LDV have same lockheed brakes. Got a new old stock Ldv on exactly the same apart from the length of the rod to the pedal. Too short just tacked a bolt onto the yolk & screwed on the yoke off my old one. Think there maybe still one on Ebay.
greek
Return to Mk 1 & 2
