Wanted: 844F 6A616 AA oil pressure relief valve 1985 Ford
Postby Garcia66 » Tue May 12, 2026 1:14 pm
Hi everyone,
I’m looking for the engine oil pressure relief / oil system valve assembly for my father’s:
Ford Transit Mk2 100
Year: 1985
Body: Van / Furgón
Engine: 2.5 DI Diesel
Engine type/code: D / 4AB
Engine size: 2496 cc
The part itself is stamped with the Ford reference: 844F 6A616 AA
I have attached photos showing:
- the complete valve assembly,
- the body, internal plunger/piston and spring,
- and a close-up of the stamped part number.
We are trying to find either:
this exact part, or a confirmed compatible replacement.
Does anyone have one available, know of a supplier, or know whether this part was used on other Ford Transit 2.5 DI engines as well?
Any help would be greatly appreciated.
Thanks very much!
Garcia66
Re: Wanted: 844F 6A616 AA oil pressure relief valve 1985 For
Postby metalworker0 » Tue May 12, 2026 5:11 pm
I can tell you its 7 digit ford part number, which is 6141432
and cant be found
suggest you go down the LDV parts catalogue route
find a model with your engine in it .. and go from there
as all ford parts catalogues we use only start at 1991 or so
but ... they have the 2.5 in a 1991 transit
so look here ... you are after the 7 digit part number
http://www.catcar.info/ford/?lang=en&l= ... FJQg%3D%3D
Postby Garcia66 » Thu Jun 11, 2026 1:02 pm
Thanks very much, Mark. I really appreciate your help and the information — I’ll look into the LDV parts catalogue and search using part number 6141432.
All the best,
Natalia
Garcia66
Postby metalworker0 » Thu Jun 11, 2026 4:29 pm
As far as i know - you CANT search LDV catologue with ford part numbers
i said find LDV 1985 catalogue and look through it
our site for looking things up begins in 1991.. although 2.5 manufactured in those years .. but dates for yours is incorrect if i did that.. i may find the wrong one . and lead you to making incorrect purchase
Postby Ralph.9 » Fri Jun 12, 2026 7:16 am
The MK2 Transit 2.5Di is basically the York engine with an upgraded cylinder head so you're probably better looking for the valve from a York engine.
Ralph.9
Postby dumper » Fri Jun 12, 2026 2:01 pm
Had a problem with the release valve can’t remember if it was a York or Di but it had worn the bush in the bottom of the block that had to be removed I did this by getting a tap that could form a thread in the bush as it hit the bottom the bush moved up the tap if you use this method put plenty of grease on the tap to collect the swarf
it was the worn bush that was the problem it was over pressurising the system thinking back it was a York as it bent the steel filter bowl
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby sierra3dr » Sun Jul 19, 2026 2:25 pm
Did you get sorted Garcia?
sierra3dr
Return to Mk 1 & 2
Users browsing this forum: Peterr
