MrMPuk wrote:Biodiesel shouldn't really make any difference as the amount of rapeseed oil is quite low.
MrMPuk wrote:You might want to check the glow plugs as these or the fuisble link in the wire could be at fault.
Nighthawk wrote:Biodiesel is a pain in the backside.
If the fuel has anything more than 5% biodiesel you'll void any warranty coverage on the fuel system...(if it has any remaining)
It has a nasty habit of gumming up the delicate workings of the pump and injectors.
Nighthawk wrote:If it contains more than 5% bio, the fuel is NOT the same and the increased warranty rejection rates across europe bare witness to this
I don't make the fuel systems, nor do I dictate policy with regards to coverage on the parts, but I do have to stick to them and enforce them where neeeded.
Ford diesel systems are designed to run on Diesel fuel meeting BS EN590 only, this standard sets the 5% limit for esterified vegetable oil
even at these levels we are having serious issues with diesels which have been run for long periods on this fuel as the build up of gum affects the workings thus reducing their ability to function correctly.
It's not a manufacturing defect and so not a valid warranty claim.
