V96 works on custom and mk7:-)
I paid someone to change my vcm2 serial number to a newer 1 and he also made a exe file that changed time and date and started vmware up and he also stopped clock time update via windows time.
Bit complicated that way tho
I also think he used a genuine ids subscription demo as it has 4 days remaining
No real use on the custom tho because to do keys or initialization it wants to go online and log in to Ford with my locksmith username and password, certainly sir I'll just go and get it
Anyway, i don't know 100% what version your vcm2 serial is valid till, maybe v91, in any case what happens is you have v86 and it identifies the van mk7 say 2.2 tdci yes?
That's fine then it'll read codes etc happy days, them when you update to say v91 it'll do the same mk7, bit then you plug billy in it'll not see the pcm:-( but then v95/6 will see billy and do codes etc, however, v86 has permanent licence, install v91 it now has 3 day licence, install v96 and you'll still have 3 days or maybe what's left I'm not sure.
That's the fun bit you need to lock it up somehow, I've never used freeze successfully, i have this exe which is a shortcut to vmware12 and when i click it, it changes the laptop time and date to 2011 January or something and it runs vmware and then i run ids from within vmware which is w8.
Once i close it down it reverts the laptop time and date back to what it should be, clever really
Pointless tho because I'm not to sure how i can emulate this into another setup
Also Karl bought a vcm ids3 fly clone which I'm waiting for him to see if it'll do keys and modules with bypassing the Ford user and password (it goes online differently see)
HTH did you get all that?
Have you done it yet?
