walt1984 wrote:I have no intentions of stirring things up.
Will there be a rwd 2.4 mtdi in a mk7 conversion? . A mate of mine is looking at a mk7 with blown engine and thinking of buying and rebuilding it as he will then know its history. Ive been telling him about the conversion thats been shown on here.
V184 wrote:Thanks for that
bigjohnthomas wrote:I am not going, you lot will tie me up and bum me
Probably
dieselhead123 wrote:walt1984 wrote:I have no intentions of stirring things up.
Hi there, it would be a natural progression to offer this.
The simplest solution being to install a Mk6 2.4 Tddi engine fitted with Mk7 ancillaries and our Mdti pump. This looks to be a simpler 'swap' than the FWD Mk7![]()
Retain the Mk7 flywheel and crankshaft sensor and the rev counter will most likely work.
mealic wrote:I can see that the campsite talk on this issue will be going on well into the "wee morn" at Mania this weekend. I really hope that everyone that has posted here will be there to defend their corner.
I somehow doubt that they ALL will. Maybe I shall be proven wrong.
walt1984 wrote:A 120/125 isnt the same type of pump that can fail on other mk6s?
Im still learning thats the only reason i ask.
paul2012 wrote:walt1984 wrote:A 120/125 isnt the same type of pump that can fail on other mk6s?
Yes Bosch VP30 & VP44 both have EDC's which do fail - Common problem
These 2 pumps are fitted to Mk6 TDDI engines.
Mk6 TDCI engines use a Delphi fuel pump with high pressure fuel rail - Known as common rail
walt1984 wrote:paul2012 wrote:walt1984 wrote:A 120/125 isnt the same type of pump that can fail on other mk6s?
Common rail been the unreliable 135ps?
