I have a Mk6 Transit with the 6 speed gearbox. For a while I've had issues with intermittent reversing light operation. When they finally stopped working altogether I sourced a replacement switch and verified that the lights worked when the switch was operated manually, it turns out that my reversing lights still don't work, or only very rarely. All I can assume is that whatever actuates the switch inside the gearbox is not doing so correctly.
Has anyone else come up against this issue?
