Where can I get injector seals?..
Postby PLEDGEY » Mon Jun 09, 2025 6:32 pm
So, 2 of the injector seals have blown (I'm calling the 'rubber seals' that sit between the injector and the cam cover the 'Injector seals') and I bought every thin I thought I would need to do the job. Took out the injectors, seals, washers, all no problem. Cleaned every thing out very carefully with a brush kit I boughtand it looked smooth and clean on the endoscope I bought. Put the copper washers in, no problem, slid the seal on the injector and put the injector in and it's too small. I don't know what I have but it ain't right. I also noticed the bolts are different as well, much longer and thinner thread. So it's Saturday and I ring Euro Parts. They say they can have what I want on Monday morning. I go there this afternoon and they have no record of me even ringing. THEEEEN they tell me they can't get them anyway as they are a Ford only part. I go over to NAPA Parts. Bloke there says yes they have what I want but it's in a kit. Seals, washers, gasket, etc. He's gone for 5 minutes then comes back ''Sorry mate the computor is showing the wrong item, it's just a gasket. Seems it's a Ford only part''. So, I got the van on the drive blocking the Mrs car, she ain't happy, and I can't get any seals. I've tried looking on the Ford parts sites on the net but can't see what I want and now I don't think I would be 100% sure even if I did see the right parts. So how do I order the washers, seals for a MK7 Transit, T280 SWB, FWD, 2.2 on a 2013 plate?, where do you guys get your seals???.........it was going sooo well...Cheers!.
PLEDGEY
Re: Where can I get injector seals?..
Postby DanMK7uk » Mon Jun 09, 2025 6:54 pm
https://www.amazon.co.uk/Transit-Parts- ... 570&sr=8-4
These should do it but delivery bit slow… you could use the part numbers to maybe find them
DanMK7uk
Postby knobby1 » Mon Jun 09, 2025 7:50 pm
PLEDGEY wrote:So, 2 of the injector seals have blown (I'm calling the 'rubber seals' that sit between the injector and the cam cover the 'Injector seals') and I bought every thin I thought I would need to do the job. Took out the injectors, seals, washers, all no problem. Cleaned every thing out very carefully with a brush kit I boughtand it looked smooth and clean on the endoscope I bought. Put the copper washers in, no problem, slid the seal on the injector and put the injector in and it's too small. I don't know what I have but it ain't right. I also noticed the bolts are different as well, much longer and thinner thread. So it's Saturday and I ring Euro Parts. They say they can have what I want on Monday morning. I go there this afternoon and they have no record of me even ringing. THEEEEN they tell me they can't get them anyway as they are a Ford only part. I go over to NAPA Parts. Bloke there says yes they have what I want but it's in a kit. Seals, washers, gasket, etc. He's gone for 5 minutes then comes back ''Sorry mate the computor is showing the wrong item, it's just a gasket. Seems it's a Ford only part''. So, I got the van on the drive blocking the Mrs car, she ain't happy, and I can't get any seals. I've tried looking on the Ford parts sites on the net but can't see what I want and now I don't think I would be 100% sure even if I did see the right parts. So how do I order the washers, seals for a MK7 Transit, T280 SWB, FWD, 2.2 on a 2013 plate?, where do you guys get your seals???.........it was going sooo well...Cheers!.
You may have got Euro-4 parts by mistake, the injectors, clamps, bolts & seals are very different.
Euro-4 here:
http://www.catcar.info/ford/?lang=en&l= ... g4NzkrMTMz
Euro-5 here:
http://www.catcar.info/ford/?lang=en&l= ... gzNjcrMTMz
Euro-4 rocker cover & seals:
http://www.catcar.info/ford/?lang=en&l= ... OSsxMzM%3D
Euro-5 rocker cover & seals:
http://www.catcar.info/ford/?lang=en&l= ... EzMw%3D%3D
Postby andz327 » Tue Jun 10, 2025 1:25 am
Yuip his is definitely euro 5 euro 4 no fitty....... you bought all the gadgets but got the wrong parts and copper washer goes on injector and the rubber seals fit on to the can cover before fitting the injector
andz327
Postby vansit1 » Tue Jun 10, 2025 11:20 am
which part of it was going well if you dont even read any answers to your own questions? :roll:
viewtopic.php?p=1872217#p1872217
viewtopic.php?p=1872337#p1872337
vansit1
Postby knobby1 » Tue Jun 10, 2025 8:01 pm
vansit1 wrote:which part of it was going well if you dont even read any answers to your own questions? :roll:
You may want to be a little more careful Sir...our admins may not take a liking to you having a go at our members.
Postby vansit1 » Tue Jun 10, 2025 8:30 pm
what the actual x are you talking about again? :shock:
vansit1
Postby Altransit » Tue Jun 10, 2025 10:19 pm
vansit1 wrote:what the actual x are you talking about again? :shock:
What he's saying is that whilst light hearted banter and leg pulling is usually acceptable, being rude to people is not, and can intimidate some members who aren't used to it.
Please be careful with the wording of some of your posts.
Postby knobby1 » Wed Jun 11, 2025 12:37 am
I wasn't pulling your leg..!! Maybe you have your pants caught in your boot.. :wink: :mrgreen:
