Pulley came off !!
Pulley came off !!
Postby Knobby2515 » Wed Dec 10, 2025 9:47 pm
2012 RWD 2.2 6 speed MK7
On my way to work Tuesday morning and I was 5 mins away from work when the steering went suddenly very heavy and no power steering.
No noises or warning lights.
As I wasn't far away from work I carried on. Managed to get round 2 roundabouts and as I got closer the battery light came on.
I made it to the car park without breaking down , phew!
As it was still cold,dark and raining I only had a quick look under the bonnet.
The main belt was slack.
Ok so maybe just a new belt needed?
Anyway in daylight and with one of the mechanics at work we had a better look.
The bottom pulley was flapping about and came off.
The rubber in the middle has sheared off/ came away from the middle.
The middle part with the bolt is still in place.
Fortunately it doesn't seem to have damaged the engine case or the radiator.
I did dip the oil and the level is still good.
I now have a new belt, bottom pulley and the twin idler/ tensioner part.
Any tips on fitting?
Also what is the torque setting for the pulley bolt please?
Thanks.
Sent from my SM-A805F using Tapatalk
2012 MK7
100 T330 2.2 with 150hp Vanunter upgrade
MWB Semi-high roof
2.2 - 6 speed RWD
Air-con, heated screen, front fog lamps, cruise control, twin slide doors
Knobby2515
Re: Pulley came off !!
Postby gt_addict » Wed Dec 10, 2025 11:57 pm
Not sure if yours is EU4 or EU5. When we did a colleagues one (2.2 eu5 in a custom) it was 45nm then 120degs on the NEW bolt.
gt_addict
Postby andz327 » Thu Dec 11, 2025 1:23 am
Crank pulley with one bolt ??
If it's 2.2 rwd its euro5
Feel how tight it is to slacken and just horse it back up until you can't
Dont buy a cheapo spurious pulley ..... with these you definitely get what you pay for
andz327
Postby Knobby2515 » Thu Dec 11, 2025 6:48 am
gt_addict wrote:Not sure if yours is EU4 or EU5. When we did a colleagues one (2.2 eu5 in a custom) it was 45nm then 120degs on the NEW bolt.
EU 5 is mine
2012 MK7
MWB Semi-high roof
2.2 - 6 speed RWD
Knobby2515
Postby Knobby2515 » Thu Dec 11, 2025 6:49 am
andz327 wrote:Crank pulley with one bolt ??
According to the diagram I have its one bolt.
Thanks for torques
2012 MK7
MWB Semi-high roof
2.2 - 6 speed RWD
Knobby2515
Postby tranmx2 » Thu Dec 11, 2025 10:10 am
Remove bumper and rad' etc for easier access.
Might help with replacing your crankshaft pulley.
From 2012 E5 2.2. Nov 2022. Timing cover not aligned, seal distorted, found one hole in timing cover too small to allow alignment.
The 5 bolts are not screwed in.
There's other ways of doing this. About 33 ft lbs + 90 degrees for each of 3 bolts. Did get about 30 degrees.
viewtopic.php?f=5&t=235787
Just seen this Crankshaft pulley tool - for £19 is an easier way of doing it.
Looks like put the pulley on, the 3 bolts in place nip up. Put the tool on - with a socket through the larger hole tighten up the bolt - tighten all three then torgue up to spec.
A pipe to extend the lever part might be required.
2012 2.2 TDCi MK 7 E 5 100 HP - 350 3.5 tonne XLWB RWD H3 L4 Duratorq 2.2L CR TC 14 DSL 100/125 PS
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM Siemens Continental fuel system.
OBD2 ELM 327 FTDI and Vlinker . Forscan 2.3.46
tranmx2
Postby Knobby2515 » Thu Dec 11, 2025 1:38 pm
Update, it is 3 bolts and am getting from Ford.
2012 MK7
MWB Semi-high roof
2.2 - 6 speed RWD
Knobby2515
Postby darren@boatfix.co.uk » Thu Dec 11, 2025 7:57 pm
Must be the season for it. Just changing belt yesterday & I happened to notice crank pulley on mine was wobbly as heck. Got the bolts undone - which were v tight- by locking engine by putting in 3rd gear & pulling handbrake on hard & holding on footbrake. Pulley did turn 1/2 a turn backwards before stopping & bolts undoing. Was terrified when I read on here about chain coming off but it didnt thank gawd. Same method used with tightening the 3 bolts. I dont think 120 degrees possible with engine in vehicle. Got it as tight as I could & will re-tighten when I get the special tool. Not sure if its certain chain tensioner is slack as there is a non return ratchet within it.
Postby Knobby2515 » Thu Dec 11, 2025 8:00 pm
tranmx2 wrote:Remove bumper and rad' etc for easier access.
Thanks for the detailed reply
2012 MK7
MWB Semi-high roof
2.2 - 6 speed RWD
Knobby2515
Postby Knobby2515 » Thu Dec 11, 2025 8:14 pm
Looking at the old pulley A few people who have seen it have all said the same thing,
Its been on the way out and hanging on for a long time. The rubber has dirt etc where it has been cracking and seperating.
MY van was in storage for a year and a half so the pulley has been on its last legs for at least a year before that.
2012 MK7
MWB Semi-high roof
2.2 - 6 speed RWD
Knobby2515
Postby knobby1 » Thu Dec 11, 2025 9:22 pm
Knobby2515 wrote:According to the diagram I have its one bolt.
Thanks for torques
It will have 3 x 15mm headed bolts.
Lord Knobrot (Smithy)
Postby andz327 » Fri Dec 12, 2025 1:58 am
Thanks for torques
Must be wrong diagram your looking at
andz327
Postby M3Stig » Sat Dec 13, 2025 5:20 pm
still to this day i dont know what made ford pick a rubber pulley over a metal one, same with the wet belt although i have a theory behind that and its to make more money by getting them replaced as timing chains dont go wrong
M3Stig
Postby Knobby2515 » Sat Dec 13, 2025 5:42 pm
Thanks for torques
Seemsso, i now have 3 bolts.
2012 MK7
MWB Semi-high roof
2.2 - 6 speed RWD
Knobby2515
M3Stig wrote:still to this day i dont know what made ford pick a rubber pulley over a metal one, same with the wet belt although i have a theory behind that and its to make more money by getting them replaced as timing chains dont go wrong
I think you are right.
2012 MK7
MWB Semi-high roof
2.2 - 6 speed RWD
Knobby2515
