(GEM Module, Hazard & indicator switches, Front wiper/wash, Air Recirculation switch etc)
NOTE - When fitting GEM module remove your old central locking module as GEM module operates central locking, if not removed then it will conflict with the newly installed GEM module !)
CENTRAL LOCKING WITH DEAD LOCKING
GEM IPL2 WH/BK UNLOCK MOTOR FRONT DOORS - C451 PIN 8 WH/BK
GEM BL11 BK/GN UNLOCK SWITCH FRONT RH DOOR C452 PIN 14 BK/GN
GEM BL12 BK/BU SET SWITCH FRONT DOORS - C452 PIN 12 BK/BU
GEM BL18 BK/YE AJAR SWITCH FRONT LEFT - C452 PIN 16 BK/YE
GEM BL19 BK/BU AJAR SWITCH FRONT RIGHT - C452 PIN 11 BK/BU
GEM BR10 BK/OG LOCK SWITCH FRONT DOORS - C452 PIN 15 BK/OG
GEM BR8 BK/WH RESET SWITCH FRONT DOORS - C452 PIN 4 BK/WH
GEM BR21 BK/WH RESET SWITCH REAR DOOR - C451 PIN 10 BK/WH
GEM BR18 BK/OG LOCK SWITCH REAR DOOR - C452 PIN 13 BK/OG
GEM BL17 BK/RD AJAR SWITCH REAR DOOR - C452 PIN 2 BK/RD
GEM BL13 BK/BU SET SWITCH REAR DOOR - C452 PIN 1 BK/BU
GEM BR6 YE DEADLOCK LEFT SIDE - C41 PIN 18 YE
GEM BR7 YE DEADLOCK RIGHT SIDE - C43 PIN 18 YE
GEM BR5 WH/GN REAR DOOR UNLOCK C52 PIN 8 WH/GN (ADD REAR DOOR UNLOCK RELAY !)
GEM EN1 YE/BK LOCK ALL DOORS - C451 PIN 3 YE/BK
GEM EN2 OG/WH VBAT LOCKING - C452 PIN 5 OG/WH F63 20A
GEM EN3 BK GND - C451 PIN 6 BK
GEM IPL10 GN/OG IGNITION - C452 PIN 7 GN/WH F48 7.5A
GEM BL16 GY EXT ANTENNA - C452 PIN 9 GY
GEM IPR13 BK/OG RADIO SENSE - C451 PIN 13 BK/OG
LIGHTS
GEM BL4 OG VBAT TURN SIGNAL - C451 PIN 2 OG/WH F61 15A
GEM BL2 BU REAR LEFT INDICATOR -C61A PIN 13 BU
GEM BL3 BU/WH FRONT LEFT INDICATOR - C451 PIN 9 BU
GEM BL1 BU/RD REAR RIGHT INDICATIOR - C61A PIN 14 BU/RD
GEM BL6 BU/RD FRONT RIGHT INDICATOR - C451 PIN 1 BU
GEM IPR18 BU - STALK TURN LEFT SWITCH PIN 6
GEM IPR17 BU/RD - STALK TURN RIGHT SWITCH PIN 7
2009> INSTRUMENT CLUSTER J1-3 BK/OG - STALK MAIN BEAM SWITCH PIN 8 (ADD LOW BEAM INTERUPT RELAY !)
2009> INSTRUMENT CLUSTER J1-2 BK/BU - STALK PASS/FLASH SWITCH PIN 9
STALK SWITCH PIN 10 BK/GN - GND
GEM BL7 OG/BK VBAT EXT LIGHTING - C320 11 PIN OG/BK
GEM BL5 OG/GN SIDE LIGHTS - C320 13 PIN OG/YE
GEM BL21 BK/BU INTERIOR LIGHTS - C813 PIN 19 BK/BU (INTERIOR LIGHT RELAY)
GEM EN6 OG/BU BATT SAVER - C14 PIN 7 OG/BU DOME LIGHTS
GEM IPR16 BK/OG - PIN 6 HAZARD SWITCH
ILLUMINATION OG/GN - PIN 5 HAZARD SWITCH
GND BK/OG - PIN 4 HAZARD SWITCH
RECIRCULATION SWITCH/MOTOR
GEM BR20 OG/GN VBAT RECIRC - C380 PIN 8 OG F59 7.5A
GEM BR15 WH/BU RECIRC MOTOR + - C375 PIN 4 WH/BU
GEM BR16 YE/BU RECIRC MOTOR - C375 PIN 2 YE/BU
GEM BR17 GN/YE RECIRC TELLTALE - RECIRC SWITCH PIN 1
2009> INSTRUMENT CLUSTER J1 PIN 18 GN/BK - RECIRC SWITCH PIN 6
C380 PIN 2 OG/GN ILLUMINATION - RECIRC SWITCH PIN 3
C380 PIN 12 BK/OG GND - RECIRC SWITCH PIN 2 & 5
FRONT WIPER/WASH
GEM IPR5 GN/RD FRONT WIPER IGNITION - C17 PIN 5 GN/RD
GEM IPR3 YE/BK FRONT WIPER WASH - WIPER SWITCH PIN 1
GEM BR23 BK/RD FRONT WIPER HIGH SPEED - WIPER SWITCH PIN 2
BK GND - WIPER SWITCH PIN 3
GEM IPR4 WH/BK REAR WIPER WASH - WIPER SWITCH PIN 4
C809 PIN 25 BK/WH - WIPER SWITCH PIN 6
GEM BL20 WH/RD WIPER DATA 1 - WIPER SWITCH PIN 7
BK GND - WIPER SWITCH PIN 8
GEM IPR7 WH/BU WIPER DATA 2 - WIPER SWITCH PIN 9
GEM IPR14 WH/GN WIPER DATA 3 - WIPER SWITCH PIN 11
GEM BL9 BK WIPER INTERVAL/AUTO - WIPER SWITCH PIN 12
GEM IPL4 WH/BU WIPER PRK POSITION - C14 PIN 2 WH/BU (CUT)
GEM IPL3 WH/BK WIPER HIGH - C441 PIN 8 WH/BK
GEM IPR1 WH/BU WIPER LOW - C14 PIN 2 WH/BU RELAY
C441 PIN 7 WH/BK & PIN 9 WH/GN (CONNECT TOGETHER !)
Wiring details for the 2009 onwards Instrument cluster will follow soon
