NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby paul2012 » Mon Oct 14, 2013 8:51 pm
Trender wrote:
tez wrote:that's what is missing off my back axle ?
Heat shield or stabilizer ? Tez
If its the stabilizer I've just checked my 2013 and mines missing as well... is that ok or should it be there ?
Not all connects were fitted with a rear anti-roll bar (stabilizer), don't understand why Ford never fitted them to all connects. :?
As it increases stability when cornering.
Bolt holes should be present for anti-roll bar clamps, so effectively you can install one no problem. :wink:
Assembly comprises of
1x Anti-roll bar (stabiliser)
2x bushes
2x clamps
4x bolts
2x droplinks
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby tez » Tue Oct 15, 2013 1:00 am
thank u paul :D
tez
Postby Trender » Tue Oct 15, 2013 8:30 am
Mine seems to handle ok without the anti roll bar but my worry is will it fail the mot for not having one sometime in the future ?
....Trender.... 2018 Limited
Trender
Postby g-man » Tue Oct 15, 2013 9:28 am
can't and won't fail as it never had one.........i fitted it about 4yrs ago and it does improve cornering
g-man
Postby paul2012 » Tue Oct 15, 2013 11:09 pm
Trender wrote:Mine seems to handle ok without the anti roll bar but my worry is will it fail the mot for not having one sometime in the future ?
As G-man says, as it was not fitted it would not fail a MOT :D
It would have been different if anti-roll bar was present, but drop links were missing - that would be a MOT failure :wink:
paul2012
Postby paul2012 » Tue Oct 15, 2013 11:25 pm
Another update on progress of dash wiring loom
Dash loom is now virtually completed - to finish is to add the 5 plugs for the GEM module.
Here is where I have added the low beam interrupt relay (behind instrument cluster)
This jumble of wiring is to be connected to the GEM module plugs :wink:
Tech info - Following dash loom wiring to be connected to GEM module.
V IGN 12v+ IPL10
POWER GND EN3
SIGNAL GND IPR2
FRONT WIPER PARK POSITION IPL4 - CONNECTS TO WIPER MOTOR
FRONT WIPER HI IPL3 - CONNECTS TO WIPER MOTOR
FRONT WIPER LOW IPR1 - CONNECTS TO WIPER RELAY
FRONT WIPER IGN 12v+ IPR5
FRONT WASHER SWITCH IPR3
FRONT WIPER HI SPEED SWITCH BR23
FRONT WIPER INTERMITTENT DATA 1 BL20
FRONT WIPER INTERMITTENT DATA 2 IPR7
FRONT WIPER INTERMITTENT DATA 3 IPR14
FRONT WIPER INTERVAL/AUTO SWITCH BL9
K-LINE (RAIN/DAYLIGHT SENSOR) BL22
INDICATOR RIGHT SWITCH IPR17
INDICATOR LEFT SWITCH IPR18
HAZARD SWITCH IPR16
INDICATOR REAR RIGHT BL1
INDICATOR REAR LEFT BL2
INDICATOR FRONT RIGHT BL6
INDICATOR FRONT LEFT BL3
SIDE LIGHTS BL5
VBAT INDICATORS BL4
VBAT EXT LIGHTS BL7
HEADLAMPS ON IPR6 - CONNECTS TO LOW/DIPPED BEAM RELAY
AUTOLIGHT SWITCH IPR21 - CONNECTS TO HEADLAMP SWITCH
FRONT FOG LIGHTS IPR20 - CONNECTS TO HEADLAMP SWITCH
REAR FOG LIGHTS IPR19 - CONNECTS TO HEADLAMP SWITCH
VBAT HORN BR4
HORN BR3
HORN SWITCH IPR15
HEATED FRONT SCREEN SWITCH
HEATED FRONT SCREEN RELAY IPL12
HEATED REAR SCREEN SWITCH IPR11
HEATED REAR SCREEN/MIRRORS RELAY IPR12
RECIRC TELLTALE BR17
VBAT RECIRC
RECIRC MOTOR BR15 & BR16
DE-ICEING SWITCH BR22
RADIO SENSE IPR13
BATTERY SAVER EN6 - CONNECTS TO BATTERY SAVER RELAY
INTERIOR LIGHTS BL21 - CONNECTS TO INTERIOR LIGHT RELAY
EXTERNAL RF ANTENNA BL16 (760mm Long)
HS-CAN LOW IPR22
HS-CAN HIGH IPR23
paul2012
Postby tez » Wed Oct 16, 2013 2:16 am
paul2012 wrote:Another update on progress of dash wiring loom
Dash loom is now virtually completed - to finish is to add the 5 plugs for the GEM module. would not no where to start there paul takes me all my time to wire a 3 pin plug never mind that lot :lol: :lol:
V IGN 12v+ IPL10
POWER GND EN3
SIGNAL GND IPR2
HAZARD SWITCH IPR16
SIDE LIGHTS BL5
VBAT INDICATORS BL4
VBAT EXT LIGHTS BL7
VBAT HORN BR4
HORN BR3
HORN SWITCH IPR15
VBAT RECIRC
RADIO SENSE IPR13
HS-CAN LOW IPR22
HS-CAN HIGH IPR23
tez
Postby paul2012 » Thu Oct 17, 2013 1:16 am
tez wrote:would not no where to start there paul takes me all my time to wire a 3 pin plug never mind that lot :lol: :lol:
It is complex & time-consuming :wink:
paul2012
Postby paul2012 » Mon Oct 21, 2013 10:42 pm
Finally finished reconfiguring the dash loom, Now I can get the dash assembly refitted :D
Pics will follow shortly :wink:
paul2012
Postby TIGGER666 » Tue Oct 22, 2013 3:48 pm
Well after reading the whole thread over a few days I must say I'm well impressed you clearly got some skills dude, it's a shame there are a few envious and jealous types on here who can't refrane from posting sarcastic and bithchy comments because they probably haven't got the skills to take on such a project themselves....
TIGGER666
Postby paul2012 » Tue Oct 22, 2013 9:24 pm
Before I refit dash assembly, Though I better check fitment for accelerator pedal.
Good job I did, typical another minor change in mountings on connects from 2006 onwards.
Something to work some magic on 8)
Also new pedal switches have arrived.
& fitted to their respected locations.
paul2012
Postby paul2012 » Wed Oct 23, 2013 8:40 pm
Cover & bracket for autowipe/light sensor arrived today :D
paul2012
Postby woolf » Thu Oct 24, 2013 9:28 pm
Ive just spent a while going through the 21 pages of this thread,fantastic!!!!
Great to see the project taking shape,your obviously very hands on to undertake all that work.Can i just ask,is there any reason why you raised the side trim above the recessed grooves and only fitted one?Im guessing just for the cleaner look........
woolf
Postby paul2012 » Fri Oct 25, 2013 2:33 am
woolf wrote:Ive just spent a while going through the 21 pages of this thread,fantastic!!!!
Thanks :D
New side trims are for a 2006 onwards connect & fitted them so it looks newer. Old ones had faded & were loose.
paul2012
Postby paul2012 » Fri Oct 25, 2013 2:51 am
TIGGER666 wrote:Well after reading the whole thread over a few days I must say I'm well impressed you clearly got some skills dude, it's a shame there are a few envious and jealous types on here who can't refrane from posting sarcastic and bithchy comments because they probably haven't got the skills to take on such a project themselves....
Thanks, Once dash is refitted there will be a couple of bit & bobs to do. Essentially it's nearly finished :wink:
Most of the work is fairly straight forward. Although I have come across the old mounting point or bracket missing, which you would normally find on 2006 onwards connects.
paul2012
