Hi Dave. Sorry to hear that, and good luck with your treatment in the new year.
I have the ND-BC2 Rear View Camera, there is a rubber grommet in the centre hole on the rear door between the 2 number plate lights, so i have run the cable through there, i haven't mounted in finally yet but i think it should tuck up there so as not to stand out too much, i think the connect mirrors are pants, (i can park my 120 Transit with my eyes shut .. not literally!) so the camera will make a big difference in those tight spaces.
The VSS Cable is a Blue & White and runs into the main control box located in the drivers footwell. The whole installation only took me 2 hours and i am a numpty when it comes to wiring, just got to get me bezel and i will be well away, also need to find soem way of hiding the unit when parked.
The FINIS PART No is 1513350 for the Ford AVIC D3 Bezel and is about £60 Retail.
The FINIS PART No is 1513354 for the Cable which allows the remote radio stalks to be used, again i dont know if this sorts the Can Bus stuff out too, it certainly has a can-bus plug on it. these retail again at about £60. i didnt need one as i don;t have that wiring on my connect.
