Hi All
My 2015 2.2 has a surging issue below 2k revs. Or holding a steady throttle, and when there's a bit of strain going up a hill.
Changed egr valve for a genuine ford one, it was ok for over a week then came back. Surging wasn't so bad with new egr valve. Compared with last one.
Cleaned the air flow and map sensor electrical cleaner seems a bit better.
Can still feel a slight surge. But I expect it will worse as it learns
On live data can see the Egr valve is causing the the surge.
Hesitation occurs like this: EGR opens, van hesitates, the MAP drops, EGR closes, power increases, and the cycle repeats.
Few people have had this problem but don't see any of the problem been solved
Thanks Ian advance lads
