Surging fault
Surging fault
Postby billykan » Wed Aug 12, 2026 7:22 pm
Hi All
My 2015 2.2 has a surging issue below 2k revs. Or holding a steady throttle, and when there's a bit of strain going up a hill.
Changed egr valve for a genuine ford one, it was ok for over a week then came back. Surging wasn't so bad with new egr valve. Compared with last one.
Cleaned the air flow and map sensor electrical cleaner seems a bit better.
Can still feel a slight surge. But I expect it will worse as it learns
On live data can see the Egr valve is causing the the surge.
Hesitation occurs like this: EGR opens, van hesitates, the MAP drops, EGR closes, power increases, and the cycle repeats.
Few people have had this problem but don't see any of the problem been solved
Thanks Ian advance lads
billykan
Re: Surging fault
Postby metalworker0 » Wed Aug 12, 2026 7:57 pm
You are going to have to monitor both EGR and turbo activity
There will be a commanded and actual pid on forscan for both
Commanded and actual on the EGR.. actual should follow commanded
also same for the turbo but not necessarily in tandom with egr
Look at them in percent
if one of them doesn't follow its commanded percent .. then that's where your fault lies
EGR. well you have a new one .. hopefully with a gearbox .. if not, suspect that
Turbo has a vane actuator .. similar type of with gearbox .. the vanes get stuck and the gearbox strips its plastic gears.
If non of them. then look for holes in the boost pipe .. common around the alternator area where it touches one of the bolts .
Re: Surging fault
Postby billykan » Wed Oct 21, 2026 9:43 am
Think I sorted my van now.
Seems to be running ok now.
Map sensor connection plug. Cleaned with the Sealey Diamond Grip Terminal Cleaner, one or 2 felt slack, tightened the connectors inside plug.
See how it goes the next few weeks. Haven't felt it surging yet.
billykan
Re: Surging fault
Postby nadab_sardar » Thu Oct 22, 2026 11:59 am
Good shout from Steve on the Grampian being the likely candidate. Dates-wise it works nicely too, and with a few WRC regulars looking for pre-Paraguay seat time it could make for a decent entry if the teams are keen to have a look at the area. Having a proper Aberdeen service park would also help the Grampian a lot, as the old Dyce setup always felt a bit tucked away for spectators.
Worth remembering though that the NE Scotland forests are exactly the sort of places being squeezed by the access issues John Fife was on about. Being tied to a WRC date might give the organisers a bit more leverage with Forestry and Land Scotland, which would be a good side effect. Fingers crossed it does the Scottish scene some good rather than just being a one-off.
areas that mostly tyre fitting company don't cover in uk.
nadab_sardar
