Muddyfunster wrote:Update on my situation
My starting issue developed somewhat
Thought it was a fueling issue so booked it in to Ford. No issues found, so they suspect compression issue... compression test confirms low compression on 2 cylinders... head needs to come off now
Bills starting to add up!
Colr6 wrote:Just taken mine apart for exactly the same reasons 2021@ 35k replaced 8 exhaust valves due to blow by and corrosion. Seats recut. The piston tops on mine were even corroded so they’ve been changed as well.
