metalworker0 wrote:110 views says they are too idle to answer
metalworker0 wrote:this is what Ford says about the ratios of an ecoblue custom transit .. i don't know your ratios .. but you do .. so .. you'll have to compare
FROM HERE - noting this is 2024 spec.
https://media.ford.com/content/dam/ford ... 024_EU.pdf
EcoBlue eight-speed auto
Gear ratio (speed at 1800 RPM)
8th - 0.616 (64 MPH)
7th - 0.742 (53 MPH)
6th - 1 (40 MPH)
5th -1.414 (28 MPH)
4th- 1.842 (21.5 MPH)
3rd - 2.872 (13.8 MPH)
2nd -3.146 (12.6 MPH)
1st - 4.484 (9 MPH)
Reverse - -2.882
Final drive 3.650:1
EcoBlue six-speed manual
6th - 0.683 (42.94 MPH)
5th - 0.780 (37.6 MPH)
4th - 0.844 (34.75 MPH)
3rd - 1.121 (26.16 MPH)
2nd - 1.952 (15 MPH)
1st - 3.727 (7.9 MPH)
Reverse -1.423
Final drive - 4.930:1
tyre 215/65-16 external diameter 27"
2tall wrote:Here's the gearing for Euro6 with different FD options:
And here's the same for Euro5:
And here are the revs @ 100 km/h in 6th gear with 235/65R16 tyres on a 2022 Custom 300:
mompracen_bs wrote:I tried various online calculators and the table shown above.
But they all indicate that to reach 100km/h, the engine should be at about 2100 rpm (not 1800 rpm as shown in the photo).
2022 Custom 300 (Euro 6)
235/65R16 (= outer diameter 28"/711mm)
6th 0.683
final drive 4.19
2100 rpm
=98 km/h/61 mph
Am I doing something wrong?
2tall wrote:mompracen_bs wrote:I tried various online calculators and the table shown above.
6th 0.683
final drive 4.19
2100 rpm
=98 km/h/61 mph
You're right, something doesn't add up with the ratios.
The ratios are from BEMM. Tried different calculations and they don't correlate with the actual rpms of my Custom. Oh well
Gear ratio
8th - 0.616
7th - 0.742
6th - 1
5th -1.414
4th- 1.842
3rd - 2.872
2nd -3.146
1st - 4.484
Reverse - -2.882
Final drive 3.650:1
Gear ratio
6th - 0.683
5th - 0.780
4th - 0.844
3rd - 1.121
2nd - 1.952
1st - 3.727
Reverse -1.423
Users browsing this forum: coonak
