Capovan wrote:Yep, should be a meshed plastic cover on same as mk1 focus has on or make your own
mrtn wrote:Gentlemen,
Apparently my fan resistor burnt because there wasn't any air flow to cool it due to a stuck pollen filter. So I bought a new filter, removed the filter frame to find a filter crammed into it HARD. The filter was original, the code correct, dealer said there's only one type of filter available: XS4H-19G244-AA, so was the filter frame correct. The problem is that the filter is 10 mm bigger on both edges and when you compress it that much it will distort enough to let air pass it.
Am I alone with it or is it normal?
