Squealing noise...pump?
Postby sparkieno1 » Sat Dec 15, 2012 4:19 pm
Hi, i bought my connect about 4 weeks ago. ive noticed a kind of squealing noise. it possibly sounds like a pump. its high pitched and kind of goes up and down but disappears when revved slightly. sounds like its coming from the middle of the dash but when i lift the bonnet the engines so noisy i cant hear it. any ideas?
sparkieno1
Re: Squealing noise...pump?
Postby blue estate » Sat Dec 15, 2012 4:22 pm
Have you changed the aux belt ? as the noise may not be the fuel pump as it's at the front but could be the pas pump as that's at the rear
MGS5 and MG5
VOLVO FH daily drive
blue estate
Postby sparkieno1 » Sat Dec 15, 2012 4:30 pm
ive not changed anything yet, i thought maybe the pas pump but i've not had a chance to have a good look at it. i don't know much about the vans but i can do basic mechanics, servicing and clutches etc. I'll try and have a look tomorrow
sparkieno1
Postby blue estate » Sat Dec 15, 2012 4:36 pm
Try a new belt frist ,as it could just be the belt is knackered
MGS5 and MG5
blue estate
Postby sparkieno1 » Sat Dec 15, 2012 4:38 pm
ok cheers, whats involved in changing it?
i should've said, its the tdci engine
sparkieno1
Postby sparkieno1 » Sat Dec 15, 2012 4:52 pm
just went out and had a listen again, it definatly sounds like a pump thats struggling to run, i'll try and have a look at the pas pump tomorrow. cheers
sparkieno1
Postby TIMO » Sat Dec 15, 2012 4:58 pm
belt tensioner and idler pulley bearings wear dry,, they squeel and chirp summat rotten PITA ,, i never cured mine fully .
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
