transit connect angel eyes custom lights
Postby ozzy g » Sun Dec 23, 2012 3:11 pm
Hi fitted some custom lights today but not sure if there working properly i can only get some light on full beam nothing on dipped and nothing when you flash or high beam can you help many thanks.
ozzy g
Re: transit connect angel eyes custom lights
Postby mattvik30 » Sun Dec 23, 2012 4:59 pm
where did you get them from?
Tourneo connect 90ps Remapped by Vantuner, Mondy interior handles, Full SS exhaust with pptuning de-cat, Chrome Sportvan Grille, Fiesta St Seats, Dvd Player with Kenwood speakers,
Clear Side Repeaters, K&N Air Filter, Sportvan Sideskirts
mattvik30
Postby ozzy g » Sun Dec 23, 2012 6:27 pm
bought them from mod you transit they plug straight in but the drl have a black and white wire not long enough to reach the battery not sure where they go
ozzy g
Postby gt_addict » Sun Dec 23, 2012 8:26 pm
Couldn't you just wire them upto the sidelights instead?
gt_addict
Postby ake » Mon Dec 24, 2012 5:32 pm
Did you not get full instructions with them?
Postby g-man » Mon Dec 24, 2012 6:46 pm
put your standard lights back for winter
g-man
Postby mattvik30 » Thu Dec 27, 2012 1:41 pm
Contact them direct as they should sort them out for you. I've got a problem with mine also but only the passengers side light when on normal beam. The rest work fine.
mattvik30
Postby Mike » Thu Dec 27, 2012 4:23 pm
mattvik30 wrote:Contact them direct as they should sort them out for you. I've got a problem with mine also but only the passengers side light when on normal beam. The rest work fine.
Send him pm? memberlist.php?mode=viewprofile&u=40850
Mike
Wind up merchant!
Postby valetech » Fri Dec 28, 2012 5:53 pm
bit confused with this.the email i got doesnt say anything about any problems just asking for help with the drls.
if you have a problem then send them back,or as you are only about 30miles away come over and i will take a look
molested by:
19s is how we roll
valetech
Postby ozzy g » Fri Dec 28, 2012 6:34 pm
Thanks for your feed back it turned out to be weak battery had to start the engine to get all lights working .
ozzy g
Postby Adam_84 » Sat Dec 29, 2012 12:34 am
Pictures?
Adam_84
Postby tez » Sat Dec 29, 2012 3:50 am
looks like he could not be arsed to drive the 30 mile fr u to hv a look at it vale lol :D
tez
Postby Mike » Sat Dec 29, 2012 9:32 am
ozzy g wrote:Thanks for your feed back it turned out to be weak battery had to start the engine to get all lights working .
And connect ALL the wires?
ozzy g wrote:the drl have a black and white wire not long enough to reach the battery not sure where they go
Mike
Wind up merchant!
Postby ozzy g » Sun Dec 30, 2012 8:36 pm
i will pop up and visit mod your transit soon
looking at some other mods but need to save some dollar
ozzy g
