2 stroke oil in diesel
Postby dannyboy81 » Fri Jan 25, 2013 2:01 pm
hi all do people still put 2 stroke in there diesel engines??? how many of you are doin this?? me personally i do put it in when i remember to :lol: all i no is it gives the fuel pump a good lube up does it have any other benifits??? please reply kind regards dannyboy81 8)
MK4 Ereg transit 80 panel van (first)
mk5 vreg 100 panel van
mk4 j reg 100 panel van 2.0 pinto
mk5 n reg 120 flatbed pickup
mk5 w reg 190 crewcab pickup tipper (present)
IF UR TRANSIT LET U DOWN IM AFRAID U FAILED UR MAINTENANCE SUNSHINE...........
dannyboy81
Re: 2 stroke oil in diesel
Postby Kedishen » Fri Jan 25, 2013 2:55 pm
it gave me more power and abit better mpg, but I only used it to blow the crud out of everything.
in my mates ldv pilot it made a huge difference. he couldn't get of fourth or above 50ish but after 2stroke he was cruising in 5th at 70mph. mind u his engine blew a seal a seal a year later which he blames on two stroke. only ran it throu engine for one tank but it blew out all the dirt holding everything together. he also claimed mpg went down after that tank, but then again, he wasn't going everywhere at a snails pace anymore.
I personally see better results from running a particular snake oil in the engine oil - my whole family uses it - its a friction eliminator and its bloody good stuff - but I shan't try to convince anyone cus not worth the effort :)
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
Postby Mfr » Fri Jan 25, 2013 3:40 pm
I use two stroke @ 250ml a tank all the time and I notice the engine is smoother. I used it on my last van two which I sold to a mate and every time I get back in I can tell he's not using two stroke as it sounds like a bag off bolts compared to when I had her :?
Mfr
Postby Breakdown Biker » Fri Jan 25, 2013 8:05 pm
I've ran some through many times and really notice how much quieter the engine sounds when I do.
Where would ya be without a can of W.D?
Mk5 hicube minibus camper conversion
viewtopic.php?f=58&t=43816
Breakdown Biker
Postby gottobedeisel » Fri Jan 25, 2013 8:14 pm
Never herd of this before but you learn somthing new every day :lol:
If it aint broke dont piss about with it
gottobedeisel
Postby fidget » Fri Jan 25, 2013 8:24 pm
it not only lubes ya pump but your injectors and valve stems aswell, i use all the time, have only had benifits from it, quieter, quicker engine, recomend it to everyone i know, cannot see why people with petrol engines dont try it, after all 2 stroke is designed for petrol. may stick some in the wifes focus to see if it helps in that,
my advise may not be right, but I like to give my 10p worth, and an answer even if wrong is nice to see.
Build: 05.03.1992
Series: 100L
Diesel 2.5 (70PS)
5-Speed Manual - MT75
Drive: RHD RWD
Axle: 4.56
Diamond White 73
fidget
Postby bortaf » Fri Jan 25, 2013 10:40 pm
Petrols dont need the lubing the diesel high pressure pumps do, the old diesel has sulpher in it that did the same job, there is sonething in modern diesel but i dont work as well as the old sulpher did hense the oldrer the engine design the better it works to quieten it, my P100 totaly loves it as did my old Di transit :mrgreen:
Not sure how it would lube the valve stems? the fuel dont touch them in Di, it goes straight in the combustion chamber :?
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby ColinJack » Sat Jan 26, 2013 11:46 pm
Use 2 stroke at about 300:1 in your diesel and next time you take the inlet manifold off or check the injectors you will be amazed at how clean they are. Sounds a bit weird, but makes an amazing difference. My Di sounds completely different with and without - much quieter and smoother when 'stroked' ... like the missus :lol:
1989 Mk3 Reimo Camper
1980 Mk2 Holdsworth Camper
ColinJack
Postby Stuart30 » Sun Jan 27, 2013 12:22 pm
Does anyone know for sure if i could use a drop of 2 stroke in my Galaxy..its the MK2 with common rail engine.
Oh and its 1.9TD...runs ok just bit to tappety for my liking.
Stuart30
Postby dannyboy81 » Sun Jan 27, 2013 12:29 pm
Stuart30 wrote:Does anyone know for sure if i could use a drop of 2 stroke in my Galaxy..its the MK2 with common rail engine.
Any diesel engine from the oldest to the newest can have 2 stroke oils i have used it in many different cars and vans of all ages it will NOT damage it at all kind regards dannydoy :lol:
dannyboy81
Postby gottobedeisel » Sun Jan 27, 2013 1:14 pm
So if you say put 5 gallon o deisel how much 2 stroke would you use :D
gottobedeisel
Postby darkbluevanman » Sun Jan 27, 2013 5:02 pm
gottobedeisel wrote:So if you say put 5 gallon o deisel how much 2 stroke would you use :D
I do 100ml of 2T oil to 20 quids worth of diesel, though with the rising cost of derv I reckon it would be 25 quids worth now!
Half the time I just glug a shot in, no real measurements, can't hurt anything if you do too much...
darkbluevanman
Postby joinerman » Sun Jan 27, 2013 5:15 pm
^^^^^^^^^^^^^^^^^ What he said ^^^^^^^^^^^^^^^^^^^^
I just slug it in as well, probably between 100 - 150 ml to 20 quids worth.
joinerman
Postby dannyboy81 » Sun Jan 27, 2013 6:32 pm
Same here I just slug it in aswell no measures at all I think Wilkinson is cheapest £3 or something but it can be bought cheaper all I no is it works :lol:
dannyboy81
Postby Kedishen » Sun Jan 27, 2013 7:00 pm
interesting you say any diesel engine can take it.
what about these modern electronic fuel pumps. can they take it? and is there any benefit with the electrics controlling everything?
Kedishen
