Central heating oil
Central heating oil
Postby Smooth Hound » Fri Jan 05, 2007 1:30 pm
hio, I dont know if any one has heard of this but a friend of my sons was saying that he runs his van on central heating oil, a mixture of 1 gallon of cheap engine oil to 5 gallons of c, heating oil, i am not sure though if he wasbeing honest or having a laugh, does any one have any knowledge of this.
mike
Smooth Hound
Postby gemini » Fri Jan 05, 2007 1:44 pm
yes it will run on it, but heating oil burns alot hotter than diesel, he may need some valves soon
gemini
heating oil
Postby sanny512 » Fri Jan 05, 2007 2:16 pm
and there will be alot of black smoke my m8 had it in his car
sanny512
Postby poppajoe » Sat Jan 06, 2007 1:34 am
I did the exact opposite once.
I ran out of heating oil on a bank holiday and put 50gals of red in - it worked a treat but smoked its nuts off, thick black soot all over the back wall around the vent!
poppajoe
Postby gemini » Sat Jan 06, 2007 1:36 am
red diesel shouldnt make it smoke
gemini
Postby MrMPuk » Sat Jan 06, 2007 2:18 am
gemini wrote:yes it will run on it, but heating oil burns alot hotter than diesel, he may need some valves soon
I'd like to see you post the differences between Red Diesel and Heating Oil bearing in mind that Red Diesel is the same as White Diesel other than the dye!
Postby gemini » Sat Jan 06, 2007 3:07 am
the additives are different
gemini
Postby poppajoe » Sat Jan 06, 2007 2:07 pm
gemini wrote:red diesel shouldnt make it smoke
I know, thtas what I thought, but it did - like a bitch! as soon as it ran through and was back to the heating oil it was fine again, no adjustment etc were made to the heating boiler - strange hey?
poppajoe
Postby Smooth Hound » Sat Jan 06, 2007 3:32 pm
What additives would be different, I wonder if it smokes more because it ignites faster or slower than diesel, meaning some is going out unburnt properly, hence the black smoke, perhaps meaning a fractional change to the timing would reduce the black smoke, and possibly its the adding of oil into the CHF that maybe reduces the ignition heat , helping to not burn the valves, Just a thought.
Mike
Smooth Hound
Postby Guy88 » Sat Jan 06, 2007 4:17 pm
Are we talking 21 second heating oil :? :?
I used to run a tractor on this 8) used to be called TVO heating oil mixed with petrol to get about 50 octane 8)
Its all in the octane (the dissinclination to ignite by compression)
Anyway 21 sec oil is about 15-20 octane parraffin is 0 and diesel is 0
21 second oil will not ignite properly in a diesel
I may have the wrong end of the stick totally :oops:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Smooth Hound » Sat Jan 06, 2007 5:53 pm
I dont know what 21 sec is so I dont know, but I believe the oil this guy was using was out of his central heating tank, just normal central heating oil. he reckoned it was the same as diesel only a bit thinner, which i suppose is why he mixes engine oil with it, just a normal cheap engine oil he reckoned, mind you i dont know how long he has had the van or anything, so we will see what happens to his engine.
Smooth Hound
Postby Guy88 » Sat Jan 06, 2007 6:49 pm
21 second oil is Kerosene :wink:
Basically parraffine with the aromatics left in (gives the Octane) :wink:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Smooth Hound » Sat Jan 06, 2007 7:00 pm
No thats different stuff.
Smooth Hound
Postby gemini » Sat Jan 06, 2007 7:16 pm
mixing normal cheap engine oil wont do his pump any good
gemini
Postby motorwise » Sat Jan 06, 2007 7:25 pm
just want to bounce an idea off you - transits run on diesel so why not fill it with that? :D
this could well have done irrepairable damage to the injection pump the correct fuel also acts as a pump lubricant and the pumps are designed with this in mind - when you start introducing any old fuel to it, it protests by breaking in a costly fashion
by any old fuel I'm not just taliking about the rubbish thats been fed to this van I'm including veg oil and biodiesel - it's rubbish and causes the owners of late diesels, particularly high pressure diesels (CDI's HDI's TDCI's etc) thousands of pounds when they go wrong
the decision is yours :)
http://www.motorwise.net
motorwise
Return to Transit Talk
