dipstick wrote:... the weather has been awful up here, sideways rain, gales,things falling on my head... so i haven't made much progress recently.
I fitted and removed the engine/transmission unit OK, measured up for the new ex manifolds, but have just found the timing chain tensioners/guides are wrecked (BOB motor has two cam chains....) so i have to pull the timing cover off, to re-do the cam chains, guides tensioners etc etc...![]()
when it stops raining i will venture out, start the fuel water and oil pipework plumbing....and try to source a rad that will fit, DOHC/Pinto one seems to be the right one...?
cheers all .....
cheers all .....
OxtonyxO wrote:got any pics
OxtonyxO wrote:will they fit the 24v then
dipstick wrote:Today has been sh1t, the wind is blowing right down the drive, so i can't get under the van without a face full of crud....![]()
.... i have had to get new cam chain guides and tensioners (FPUK are recommended, good service and almost reasonable prices ...), I made a crankshaft locking tool, to hold the crank at TDC while i pull off the crank pulley and the timing cover to replace the tensioners/guides.... hassle hassle![]()
still, it might not be raining tomorrow.....
Cheers ......
