'94 Transit SWB.. advise please!
Postby Boycie » Sun Sep 11, 2005 7:05 pm
Hi guys,
new member alert!!
I've been offered a 1994 'L' plate Transit SWB.
It's a 2.5D, in pretty reasonable/ presentable condition throughout with long MoT and tax.
I'm a total beginner when it comes to these beasts so need some pointers!!
What should I look for when viewing it?
I know the seller well and he has had no bother with it at all, it's got a fully reconditioned engine but he says the rear axles has a slight whine.
He also says it has a 2-ton rear axle..?? What does that mean!?!?! It sits up pretty high compared to others I've seen and has chunkier tyres.
All this for £550..
Worth it?!
Thanks for reading !! :D
Boycie
Postby Luke » Sun Sep 11, 2005 7:15 pm
Hi mate welcome on board! :D
have a look in buyers guide theres some tips in there! (i'll not repeat them here!)
The axle whine isnt a normally a problem they can oftern whine for years before giving up (and you can generally tell thats going to happen) just check the oil! :)
the worst thing about the 2ton ones (should have 6 wheel nuts each wheel) is the ratio is very low and if you intend to do loads of motorway miles it may become a problem - more annoying than owt else! :x
but if you intend to fill it with sand, bricks, or anything heavy then there the buisness!!! :D
if the body work is tidy (and remember were not talking family saloons! :lol: ) then the price seems fair!! :)
:D
Postby Boycie » Sun Sep 11, 2005 7:29 pm
Hi Luke,
Thanks for the reply!!
I've scanned the buyers guide so am a bit more genned-up now!! :idea:
It apparently had the odd patch of rust on the arches, which were cut out and new metal buzzed in. It's solid but not saloon-car pretty!!
Rest of the van seems pretty rust and dent free.
It does indeed have 6 wheel-nuts on each corner!
Oh, one other thing.. would you know the braked towing weight?
I occasionally shift motors about with a fair-sized (braked) flatbed trailer. I appreciate it aint gonna be anywhere near my (overpriced and unreliable) Discovery, but is it up to it?
Cheers!! :)
Boycie
Postby Luke » Sun Sep 11, 2005 7:55 pm
mate it will pull a house down!!! :lol:
i'd guess towing weight would be around 1500kg on a braked trailer - not sure though - mines spot on towing and that will be better!!! :D
Di's are a great work horse of an engine!!! :D
Postby Boycie » Sun Sep 11, 2005 11:49 pm
luverly jubbly!
So it's a 'Di' right??!
Are there different types of Diesel engines? Some good, some bad?!!
Cheers for the advice :)
Boycie
Postby Luke » Mon Sep 12, 2005 12:54 pm
Boycie wrote:So it's a 'Di' right??
Yeah it's a Di
there are different types,the early mk1s and 2s had perkins and yorks before the Di's! but all mk3,4,5s have Di's, some turbo Di's aswell, and the later ones have a duratec Di (there better but you wont get one for £500 :lol: )
Basically Di's was introduced in the mid 80's and was ahead of its time but by the late 90's was getting dated!! they are a noisy and unrefined but do the job very well!!
the best ones are the banana manifold ones - called so cos the manifold looks like a bunch of bananas!!
Basically test drive it, thrash the bo**oks off it if it doesnt loose power at all should be ok!!
Can't really go wrong for the price!!! :D
l reg di
Postby john leeman » Mon Sep 12, 2005 7:38 pm
well done mate sounds like you have got a 150 van,but with all di s get some one to check the timing belt, if they snap it gets very expensive, & put the best oilyou can afford in the engine.
35 years of driving,repairing,sleeping in transit's lovin every minute.
john leeman
Postby Boycie » Tue Sep 13, 2005 9:57 am
Thanks guys,
I bought it in the end!!
It drives as it should (engine, box, clutch etc all fine) but the rear axle whines a bit when the van is empty.
Doen't drop any oil too so that will please the neighbours :lol:
Boycie
