DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby BUNGAL » Fri Mar 15, 2013 2:11 pm
andrusl wrote:
BUNGAL wrote:Can some one look up this please not sure if it will as I think it's a private plate so not sure if it is accessor
L25krj
190 transporter
We are sorry, but no information could be found for the VIN/Registration number you entered - L25KRJ
VIN please :)
Here you go, past mot today so can loll at vin
Sfaaxxbdvarj50736
BUNGAL
Postby jolly olly » Fri Mar 15, 2013 7:18 pm
BUNGAL wrote:
L25krj
190 transporter
VIN please :)
Sfaaxxbdvarj50736
* Illustration shows model only
Transit 1992-1994, Diesel 2.5 (80PS), Diamond White 73
VIN Number: SFAAXXBDVARJ50736
Registration Number: VIB2875
First Registration Date: 16.06.1994
Registration Country: GB
Primary Features
Build Date: 26.05.1994
Vehicle Line: Transit 1992-1994
Cab Style: Single Cab (2 Door)
Series: 190
Engine: Diesel 2.5 (80PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.14
Emission: EEC 5TH Emission Requirements
Territory: (+)"GB"
Paint: Diamond White 73
Interior Colour: Slate Grey
Interior Fabric: Saturn
Life is not a dress rehearsal
jolly olly
Postby kevn95 » Sat Mar 16, 2013 5:33 pm
Newbie here, could you give me details of my van y196vgf, thanks kev
kevn95
Postby jolly olly » Sat Mar 16, 2013 11:52 pm
kevn95 wrote:Newbie here, could you give me details of my van y196vgf, thanks kev
Transit 2000-2006, 2.0L Duratorq DI (75PS), Diamond White 73
VIN Number: WF0VXXBDFV1M60395
Registration Number: Y196VGF
First Registration Date: 01.05.2001
Primary Features
Build Date: 21.03.2001
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van LCF
Series: 300S Series
Engine: 2.0L Duratorq DI (75PS)
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.23
Emission: Light Duty Truck Stage III
Air Conditioning:
Territory: (+)"GB"
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-H-C)
Minor Features
With Low Roof
Less Roof Line Conversion
With Rear Mudflaps
With Front Mudflaps
With Full Partition - Steel
Less RH Side Loading Door
LH Sliding Side Cargo Door - Low
With Hinged Rear Loading Doors
With 180° Cargo Door Check Arms
With Standard Liftgate
Southampton Plant Built
BT Distribution Technician Pack
With SVO Application/Label
Marketing Level 3
With Fixed Rear Window
With Rear Blanking Panel
Less Heated Rear Window
With Heated Rear Window
Less Header Mounted Package Tray
With Header Mounted Package Tray
Less Inter Cladding Surfaces
With Partial Headlining - Moulded
With Full Headlining - Moulded
With Roof Height Feature Pack 1
With Roof Height Feature Pack 2
With Door Map Pocket
With Front Roof Grab Handle
Less Load Compartment Loops
Less Load Area Protection Kit
Less Cargo Stowage Rack/Rail
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
Less Rear Step
Less Rear View Mirror
Large Head/Short Arm Mirror
Passenger Lrg Head/Short Arm Mirror
With Drivers Seat Fixed Armrest
With Passenger Seat Fixed Armrests
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With Driver 6 Way Mnl.Seat Adjuster
With Pass 6 Way Manual Seat Adjust
Less Trailer Towing Attachments
Fleet Key
With Door Dead Locks
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
Rear Plastic Grey Bumper-With Step
With Driver Air Bag
With Spare Tyre Security Package
195/70R 15C LI 104/102 BSW
Any Brand Tyre Vendor
Less Engine RPM Control
Less Anti-Lock Braking System
With High Back Front Seats
With Manual Clutch
Less Rear Seat Climate Control
With Pollen Filter
With Recirculating Heater
Less Rear Compartment Heating
With MPH/KMH Speedometer
Heavy Duty Battery
Less Deep-Discharge Batteries
With Radio Pre-Equipment Pack 1
2000NT Series
With Power Point Plug
With Interior Courtesy Lamp
With Load Compartment Lamp
Less High Mounted Stop Lamp
With Manual Headlamp Levelling
With Auxiliary 6 Fuse Box
jolly olly
Postby DesmoDave » Sun Mar 17, 2013 12:04 am
Can someone please etis mine SP52 ZXC.
DesmoDave
Postby jolly olly » Sun Mar 17, 2013 12:14 am
DesmoDave wrote:Can someone please etis mine SP52 ZXC.
Unable to Locate Information for the Vehicle Data
We are sorry, but no information could be found for the VIN/Registration number you entered - SP52ZXC
Click here to check and re-enter the information you supplied.
©Copyright, Ford Motor Company 1994 - 2013 | Privacy Policy
Action took 24 ms. on eccvas510
jolly olly
Postby DesmoDave » Sun Mar 17, 2013 12:42 am
Thanks for trying, i`ll post VIN number tomorrow.
DesmoDave
Postby jjoiner1 » Sun Mar 17, 2013 10:21 am
jolly olly wrote:
jjoiner1 wrote:Hi, be good to know all the details please....
EO09 DYM...changed the reg yeaterday to private plate so not sure if it will work...
Thanks in advance
Transit 2006-, Duratorq TDCI 2.4 (140PS), Tango (Metallic)
VIN Number: WF0XXXTTFX9U70401
Registration Number: EO09DYM
First Registration Date: 08.04.2009
Type Approval Number (TAN): E1*2007/46*0248
Primary Features
Build Date: 26.02.2009
Vehicle Line: Transit 2006-
Series: 350L Series
Engine: Duratorq TDCI 2.4 (140PS)
Transmission: 6 Speed Manual Transmission-MT82
Drive: RHD RWD
Axle Ratio: 4.27
Emission: Stage IV Emissions
Territory: (+)"GB"
Paint: Tango (Metallic)
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
Minor Features
With Medium Roof
With Rear Mudflaps
High Door Height
With 256° Cargo Door Check Arms
Otosan (Turkey) Plant Build
Marketing Flex Prep Pack 60
Less SVO Application/Label
With Power Equipment Group
Marketing Level 3
With Visibility Pack High
With All Light Tinted Glass
Less 2nd Row RH Side Window
With Heated Windscreen
With Load Space Tie Down Loop
Less Rear Window Protector
Less Rear Step
Less Passenger Seat Armrests
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less 6th Row Seating
With Drivers Heated Seat
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
With Driver 8 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Rear Seat Armrest Packs
Less Rear Seat Packs
Rain Sensor - Fr Windscreen Wiper
Less Rear Seat Belts
With Passenger Air Bag
With Single Rear Wheels
4 Wheel Anti-Lock Braking System
Less Anti-Spin Traction System
4X4 1 Speed Transfer Case With TOD
With Sngle.L/B Dvr/Dual L/B Pass.St
Fuel Tank - 103 Litre
Leather Strg Whl-Air/Bag+Crse Cont
With Trip Computer
With Reverse Proximity Sensor
Extra Heavy Duty Battery
Low Level With Nav/CD/AM/FM Radio
Ice Feature Pack 15
With Telephone Prep Pack - Design B
Voice Activated Module - British
With Col Stalk Rado Contr W/PTT-BTN
With Front Fog Lamps
With High Mounted Stop Lamp
With Automatic Headlamp On/Off
With Instrument Panel Dimmer Switch
Thanks very much...Didnt know it had heated seat!! How dya switch tat on? Also whats the ice feature pack??
jjoiner1
Postby kevn95 » Sun Mar 17, 2013 10:37 am
Brilliant, thanks a lot.
Kev
kevn95
Postby DesmoDave » Sun Mar 17, 2013 9:36 pm
Here`s the VIN number WFOLXXBDFL2B55767
DesmoDave
Postby Sicktranny » Sun Mar 17, 2013 9:47 pm
hi can some on do etis on my van. reg is NA05DZR,
many thanks Nigel
Sicktranny
Postby jolly olly » Sun Mar 17, 2013 10:22 pm
Sicktranny wrote:hi can some on do etis on my van. reg is NA05DZR,
many thanks Nigel
Transit 2000-2006, 2.0L Duratorq DI (85PS), Diamond White 73
VIN Number: WF0VXXBDFV4S11825
Registration Number: NA05DZR
First Registration Date: 15.03.2005
Primary Features
Build Date: 26.11.2004
Series: 280S Series
Engine: 2.0L Duratorq DI (85PS)
Drive: RHD FWD
Axle Ratio: 4.54
Territory: (+)"GB"
Interior Fabric: Stylize (-G-C)
Minor Features
With Low Roof
Marketing Level 3
Less 2nd Row LH Side Window
With Complete Rear Hardboard Trim
With Cargo Stowage Rail (Mid)
Fleet Key
With Driver Air Bag
195/70R 15C LI 100/98 BSW
Cold Start Up To -20%c
With Manual Clutch
4000 Series
jolly olly
Postby DesmoDave » Sun Mar 17, 2013 11:11 pm
Can someone please etis mine SP52 ZXC. Here`s the VIN number WFOLXXBDFL2B55767
DesmoDave
Postby DesmoDave » Wed Mar 20, 2013 11:23 am
DesmoDave wrote:Can someone please etis mine SP52 ZXC. Here`s the VIN number WFOLXXBDFL2B55767
found it on http://www.auto-vin-decoder.com/ford.html
This model system was recognized. If you think that the wrong decoder decode your VIN code. You can broaden his options by filling out the form here.
Ford Motor Company
Ford Motor Company
Ford Motor Company is an American multinational automaker based in Dearborn, Michigan, a suburb of Detroit. The automaker was founded by Henry Ford and incorporated on June 16, 1903. In addition to the Ford and Lincoln brands, Ford also owns a small stake in Mazda in Japan and Aston Martin in the UK. Ford's former UK subsidiaries Jaguar and Land Rover were sold to Tata Motors of India in March 2008. In 2010 Ford sold Volvo to Geely Automobile. Ford discontinued the Mercury brand after the 2011 model year.
Model
Transit 2000-2006
Model line 350M Series
Model Year 2002 / 9
State Europe - Germany Germany
Assembly plant Unknown
Production plant Brentwood, Velká Británie (vlastní produkce)
Serial number 55767
Další informace:
Build Date: 10.10.2002
Model: Transit 2000-2006
Body: Regular Cargo Van
Model line: 350M Series
Engine: 2.4L Duratorq DI (120/125PS)
Gearbox: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 4.63
Territory: (+)"GB"
Paint: Dark Blue
Interior Fabric: Stylize (-I-C)
Note: With Medium Roof
With Rear Mudflaps
With Front Mudflaps
LH Sliding Side Cargo Door - High
Marketing Level 3
With Narrow Body Moulding
With Passenger Seat Valance
With Driver Air Bag
215/75R 16C BSW Tyres
With H/B Sngle.Drv & Dual Pass Seat
With Manual Clutch
With Pollen Filter
2000NT Series
DesmoDave
Postby transitladt350 » Thu Mar 21, 2013 9:15 pm
hi im thinking of buying this van could someone tell me a bit more about it ng09cyc thanks
transitladt350
Users browsing this forum: Google [Bot], lucbruna
