lucas epic diesel injection pump
Re: lucas epic diesel injection pump
Postby Altransit » Wed Jan 16, 2013 11:30 pm
danderv wrote:Some will say the epic never fails and its the timing belt but i can safely say i have never seen timing out on removal of a faulty pump. :D
We've seen a few on here though, so always worth checking before the pump is condemned :idea:
Postby AndyG » Thu Jan 17, 2013 11:31 pm
Never say never :!: :lol:
So what are the top 3 fails on an EPIC pump then :?:
Postby helstone » Sun Jan 20, 2013 3:21 am
Halo ford transit friends. i have a 1997 ford transit and I have the same problem as many people already explained about the leaking on the solenoid valves.A member Mr. psv-hgv-flt give many picture which is showing who to replace the lucas epic fuel pump whit a Bosch pump. I have a question a bout one cable which i saw in the picture what is t for??? It,s just a single one which has a blue connection.. Then i would like to know what is to do with the connection from the old lucas pump which was connected to the 4 solenoid valves. Is there not a electrician fold to the electronic box??Then the Number what i can see on the Bosch pump is that the number to order???
helstone
Postby gingerbob123 » Wed Jan 23, 2013 1:25 am
all you need is a bosch manual pump. pull the pats system off the back if it has 3 wires coming out the back so it just runs one wire from the stop solenoid straight to the 3rd live on the ignition and put the manual throttle pedal and cable on and its job done. can easily be done in under 2 hours. just takes a fiddle with the timing and fuel pressureto get it right.
gingerbob123
Postby psv-hgv-flt » Sun Feb 03, 2013 10:39 am
helstone wrote:Halo ford transit friends. i have a 1997 ford transit and I have the same problem as many people already explained about the leaking on the solenoid valves.A member Mr. psv-hgv-flt give many picture which is showing who to replace the lucas epic fuel pump whit a Bosch pump. I have a question a bout one cable which i saw in the picture what is t for??? It,s just a single one which has a blue connection.. Then i would like to know what is to do with the connection from the old lucas pump which was connected to the 4 solenoid valves. Is there not a electrician fold to the electronic box??Then the Number what i can see on the Bosch pump is that the number to order???
that wire is part of the loom on an ldv convoy wich is there as standard for non epic turbo fuel pump.
psv-hgv-flt
Postby Vini'sAutoserve » Sun Mar 31, 2013 6:15 am
gingerbob123, can you go through the timing fiddle you talk about and how does one adjust the fuel pressure, is there an adjustment mechanism for this?
vini
Vini'sAutoserve
Postby V184 » Mon Apr 01, 2013 8:53 am
If the timings out it throws up "timing code" on a tester :)
V184
Postby AndyG » Mon Apr 01, 2013 7:02 pm
V184 wrote:If the timings out it throws up "timing code" on a tester :)
Where do you plug this "tester" on a manual Bosch pump :?:
Postby V184 » Mon Apr 01, 2013 7:17 pm
Was referring to this :roll: :roll: :roll:
V184
Postby beany59 » Thu Apr 10, 2014 10:43 am
Hi Guys I live in Australia my problem is that I need a pump for a 1997 auto transit unable to get one here can anyone help.
Phil
beany59
Postby gassie2005 » Tue Jan 08, 2019 11:09 am
I have the same problem with my lucas epic fuel injection pump can anyone tell me where I can buy a seal from? Cheers!
gassie2005
