MK1 sump plate removal
Postby Ellwood » Mon Apr 29, 2013 6:18 pm
Hi, when replacing my distributor a few weeks ago, the hexagonal steel shaft fell down into the sump,( because i didnt shove enough grease into it)
Anyway i thought i could just drop the sump plate, but surprise surprise everything down there was too tight to totally remove it, I managed to squeeze in my hand and get the shaft out, but wondered afterwards how to get the sump plate off if necessary sometime. Has anyone else had this problem ? As i see it, its either loosen the gearbox bell house a tad, or maybe jack the engine back. its only a matter of a few millimeters, but a bit irritating.
Ellwood
Re: MK1 sump plate removal
Postby mb4ever » Mon Apr 29, 2013 6:44 pm
What do you mean by a sump plate please Ellwood?
mb4ever
Postby Ellwood » Mon Apr 29, 2013 10:31 pm
the oil tray under the engine
Ellwood
Postby mb4ever » Tue Apr 30, 2013 7:54 am
Would you have enough room if you undo the engine mountings, and lift the engine with a hoist Ellwood?
By the way, I simply call 'the sump plate' 'the sump'. :wink:
mb4ever
Return to Mk 1 & 2
