Mk7 twin battery question
Postby AlexHerts » Sun May 19, 2013 6:31 pm
Just bought a mk7 transit which has been sitting about for 6 months and the batteries are dead, always needs jumpleads.
After a quick search on the forum, i see it is probably the front battery (100 one) that needs replacing, but is it worth replacing the larger 110 battery too?
what does that one control?? - Also, silly question but will dead batteries affect the vans overall performance and mpg?? :D
AlexHerts
Re: Mk7 twin battery question
Postby blue estate » Sun May 19, 2013 6:40 pm
Yep straight swap and it controls locking lights ecu etc as for mpg yes it will till it relearns
MGS5 and MG5
VOLVO FH daily drive
blue estate
Postby motorman116 » Sun May 19, 2013 6:42 pm
It would be best to replace both batteries at the same time.
The front battery is the Aux battery, does all the electronics
The rear battery is the starter battery
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby AK » Sun May 19, 2013 7:55 pm
I just replaced my two batteries on the mk7 £110 for 2 top spec exide ones, so its not to expensive, and well worth changing both at the same tome for peace of mind
Andrew
59 plate merc splinter Luton, 56 plate 100 TDCI 350 Crew/Camper conversion
AK
Postby shauns » Mon May 20, 2013 7:31 am
Is it easy to convert a single battery set up to a two battery set up????
shauns
Postby blue estate » Mon May 20, 2013 7:46 am
shauns wrote:Is it easy to convert a single battery set up to a two battery set up????
There is a guide on here some where with parts list
MGS5 and MG5
blue estate
Postby ake » Mon May 20, 2013 12:13 pm
Postby pat4d » Wed Aug 21, 2013 12:43 pm
I am looking at fitting a twin battery split charge to my MK6 are OE parts available for this to? Are there any differences I should be aware of?
Thanks, Pat.
pat4d
Postby ake » Wed Aug 21, 2013 9:48 pm
pat4d wrote:I am looking at fitting a twin battery split charge to my MK6 are OE parts available for this to? Are there any differences I should be aware of?
Thanks, Pat.
There was no split charge option on mk6, the batteries were just linked together
Postby pat4d » Thu Aug 22, 2013 9:02 am
Ok thanks, I will make something up. Cheers, Pat.
pat4d
Postby Hallii » Thu Aug 22, 2013 2:10 pm
It isn't worth making one, you can buy one for £5.99 and it will shove 20 amps into the second battery.
http://www.ebay.co.uk/itm/Ryder-TF1170- ... 1104073477
Geoff
2007 2.2 130PS 350 LWB Motorhome
Hallii
