mk7 transit ijectors
Postby johnson » Mon May 20, 2013 12:52 pm
hi could any one tell me that if i have unpluged all the injectors to take them out have thay got to be reprogramed and if there not will the van start still or not???? because thay were all unpluged to take the injectors out cause there was a little oil leak on the seal so now solved the leak but need to now if van will start with out reprogameing the injectors back in cause i was told that thay have got to be programed in if you unplug the gray plug to the top of injectors is that true or will it still start ??????? thank you
johnson
Re: mk7 transit ijectors
Postby angeleye » Mon May 20, 2013 6:53 pm
if you put them back in same cylinders they came from they wont need programming ,it should still start and run ok even if you dont put them in same cylinders,the programming is basicly a fine tuning for injectors which makes them last longer as well
angeleye
Postby djohnson » Wed May 22, 2013 12:08 pm
hi thanks for your reply and sorry that iv not be able to reply i have had problems loging in but ok now. i am going to take my van into a garage in the morning at 8.30 to be put onto there fault finder to see what is wrong and i will reply and let you know what is wrong after there have dont it so many thanks for your help and hopfully it will be fix tomorrow.
djohnson
Users browsing this forum: Bing [Bot], Majestic-12 [Bot]
