P0340 P0335 Transit connect 230
Postby ming » Sat Jun 15, 2013 11:26 am
Hi all. This is my first post, shame it's not a happy one. I'm posting his here in the hope that someone who knows more than me can point me in the right direction. My local garage suugested seeing an autoelctrician.
I have an 03 connect tdci with around 130k on the clock.
I have had an ongoing running fault for the last few months, glow plug light flashes followed by the engine cutting out. It's steadily getting worse until now sometimes it wont start at all. Local garage read the codes and said it was the cam sensor which they changes twice. The first was from a motor factor the second a genuine ford part. Fault didn't improve.
I got myself a code reader on ebay and read the codes then cleared them. Re reading them after it played up again. I got cam sensor P0340 twice and the cranks sensor fault codes. Installed a ford crank sensor and the problem still remains. I'm guessing it could be wiring. I called ford yesterday to ask if my van would need the updated connector for the cam sensor. they said no. Are there any other parts that can be at fault within these circuits to cause the problems. Or are there any common areas of wiring that break down. Seems a coincedence that both sensors/circuits are at fault unless they share some circuitry.
Anyone have any ideas.
Thanks Nevil
ming
Re: P0340 P0335 Transit connect 230
Postby paul2012 » Sat Jun 15, 2013 5:45 pm
Welcome to the forum :D
P0340 Camshaft sensor
P0335 Crankshaft sensor
check here :arrow: viewtopic.php?f=54&t=124877
8/17/05 Poor power; delayed accelerator response and/or rough idle, engine hard or impossible to start
Poor performance Delayed throttle response Rough idle or hard to start and WDS checks reveal that either diagnostic trouble code (DTC) P0340 or P0335 is set, the probable root cause is a loss of signal from the CMP sensor. To rectify the concern, a new CMP sensor and electrical connector should be installed as required.
Due to various changes to the CMP sub-system throughout the listed products program cycles, it is necessary to make sure that the wiring loom side electrical connector is compatible with the CMP sensor in the event of a new CMP sensor being installed.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby ming » Sun Jun 16, 2013 12:33 pm
Thanks for the reply Paul. I had already found that one. That's what prompted me to talk to ford about the connector upgrade. They were adamant that my van didn't need this upgrade.
Is that written by ford? Are they saying the connector may need changing or a big chunk of the wiring. Not really sure where that leaves me. I was thinking maybe bad conection or bad wiring. I'm really hoping for suggestions.
ming
Postby paul2012 » Sun Jun 16, 2013 2:29 pm
Yes that was the TSB done by Ford :wink:
I does suggest the the connector may require replacing & was a fault identified by Ford
Since sensor has been replaced, then I would check the wiring as it appears to be an intermittent fault which is getting worse.
paul2012
Postby ming » Sun Jun 16, 2013 4:50 pm
Thanks Paul. I will check it out. Looking at you connect project thread you seem to be pretty clued up with these vans. Nice job btw. Perhaps a continuity test on the wiring back to wherever it goes to may be a help. do you know where the wiring for the cam and crank sensors end up. If there are any other plugs or connectors on their routes I guess they could also be looked at and cleaned and tested. But what is their destination. Is there any reference you can point me to for pin conectors relating to these two sensors throughout their routing.
ming
Postby paul2012 » Sun Jun 16, 2013 5:46 pm
Thanks 8)
This should help :D
2003-2006 TDCI Engine Sensor wiring diagram
Delphi ECU plug pinout Location Behind O/S kick panel below dash
C93 Plug pinout Location N/S in engine bay just above gearbox
C94 Plug pinout Location N/S in engine bay just above gearbox
Crankshaft sensor plug pinout Location back of engine next to gearbox (near VSS sensor)
I have no diagram for the Camshaft sensor plug although pins should be numbered on the plug :wink:
paul2012
Postby ming » Sun Jun 16, 2013 6:21 pm
:D Nice one Paul. That should keep me busy for a while.
I have been told all sorts of things it could be. Some sound reasonable. Others look ridiculous to me. However I'm no proffessional. I am a little shocked at how differant technicians come up with such differant fixes. So far I have been told it's the
Diesel pump
injectors
wiring
accelerator pedal
glow plugs
ecu
flywheel. ( mine has a single mass )
sender unit
fuel lines
Difficult to judge how likley some of these are but a good starting point seems to be to get to the bottom of the fault codes I'm getting. If it turns out that the vans brain is storing these codes when all the sensors/wiring are good then maybe the next step will be to get the pcm ( ithink thats its name ) checked out.
On a differant note. what would be the effect if the van had the wrong values for the injector codes. I looked at mine using F super and all four have the same codes stored. The codes are 0000 ffff 0000 ffff. I tried to correct them using f super again putting in the codes on tghe ring on each injector. All seems to go weel but after the proccess is finished and I start the van, when I read the injectors again they have returned to the values above.
I assumed that f super is too naff to perform this function but could it be a fault with the PCM. I guess it's possible.
ming
Postby paul2012 » Sun Jun 16, 2013 6:48 pm
Thats a long list :lol:
I always read the DTC codes first, this is the most accurate way to point you in the right direction.
Clear the codes & see if the same ones are storeed again.
The Injectors you have are Delphi & should be coded to the ECU :!:
I have heard the issue with the F-super not coding the injectors to ECU properly, Try doing them one at a time.
paul2012
Postby liteace » Mon Jun 17, 2013 1:24 pm
The injector maybe coded OK but as your van is 03 it may not possible to read the injector codes. On early vehicles you will see 16 zero's, 16 "F's" or a mixture of both, if the injectors are not coded you would get P2337, P2338 & P2336 with lack of power and black smoke but it would not cut out
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
Postby taz666 » Mon Jun 17, 2013 9:32 pm
can I just add this from the ford tsb on this concern
Check the vehicle build date. Is build date after 08/2002 for 2.0L Duratorq-TDCi (Puma) Diesel or 11/2002 for 1.8L Duratorq-TDCi (Kent) Diesel?
•YES - No CMP wiring loom side electrical connector update is necessary.
•NO - Go to the next step.
2. Check the colour of the CMP sensor. Is the CMP sensor grey or black?
•GREY - No CMP wiring loom side electrical connector update is necessary.
•BLACK - Install a new CMP sensor and CMP sensor electrical connector.
now as you have changed the CMP twice can u remember what colour the original one was?????
taz666
Ford Technician
Postby ming » Mon Jun 17, 2013 10:07 pm
Thanks for you help guys.
Taz the one I took out originally was grey but I guess there is no garauntee it was the original one. How would I find out these detailS on engine model and manufacture date?
I haven't had a chance to do it yet but does my plan to try and inspect and test the wiring to the two sensors sound about right? Is there any other way I can test the two circuits.
ming
Postby taz666 » Mon Jun 17, 2013 10:16 pm
ming wrote:Thanks for you help guys.
whats the registration number?, the engine will be a 1.8 kent engine, the tsb also relates to mondeos and transits which are 2.0
taz666
Ford Technician
Postby ming » Mon Jun 17, 2013 10:26 pm
It's on 03 1.8 I don't know a lot about it but I know it has delphi fuel system parts with the spider like common rail. Are they decent engines. I love the van but have had a tough time with all this. I want to stick with it as I hear they are really reliable most of the time.
ming
Postby taz666 » Mon Jun 17, 2013 10:27 pm
what is the reg number as I can see when the build date was
taz666
Ford Technician
Postby g-man » Mon Jun 17, 2013 10:28 pm
connects have the lynx engine......kent was petrol
g-man
