Puk, a troublesome fairy!
Re: Puk, a troublesome fairy!
Postby jonochap » Fri Jun 21, 2013 11:21 pm
Oh. Looking at the pics on the intermanet, that looks like an engine out jobby :(
jonochap
Postby robbie.cee » Sat Jun 22, 2013 9:51 pm
jonochap wrote:Oh. Looking at the pics on the intermanet, that looks like an engine out jobby :(
least the pinto is quite light !!
not the end of world, was gonna need doing at some point anyways!
might have one here il look tomo! :P
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby jonochap » Sat Jun 22, 2013 11:28 pm
Thanks Robbiemate, had a Lakeside expedition today, the slick at ikea is us :)
jonochap
Postby FredTransit » Sun Jun 23, 2013 8:23 am
I agree with Mutts. Jono you do like to tinker dont you. Somtimes its best to just fix things that are ACTUALLY broken!! :lol:
FredTransit
Mk2 Trannyist
Postby jonochap » Sun Jun 23, 2013 10:08 am
Thanks chaps...i do discuss the stuff i do with mvm and have a plan of attack. The stuff we have done has been (hopefully) logical. All the oil seals we have done were shot, im just running out of resources at the mom and time to go away is looming :( how complicated is this next seal? And where does it sit? The pics on the net arent that useful...puks meant to be in suffolk next weekend and maldon classic the weekend after...
Im also not sure whether fixing the seals is chasing the oil pressure to the next weakest point. I cleaned off an awful lot of caked oil last week...
jonochap
Postby FredTransit » Sun Jun 23, 2013 1:24 pm
If its not actually p1ssing out I would keep a close eye on the oil and do it if it gets much worse, or when you have less use for the van. You can get get oil on the clutch though, making it judder.
FredTransit
Mk2 Trannyist
Postby jonochap » Sun Jun 23, 2013 1:43 pm
Thanks Fred, i have thought alot about what you said. I dint think i have been wrong in the works but changing the main rear seal (now im a you tube expert) may have been better done when we changed the gearbox. But hey, who knew and whats done is done, although this may help someone else.
That said, yes, its quite alot of oil and not pretty so i will have to do something pretty quickly. My only fear is that we do this one and the next one goes.
We are saving the front seals for a timing belt change and front service maybe end of this year, beginning of next.
Are there any other bits engine side (gearbox side is good) its worth considering if i can get this arranged with the chief engineer?
jonochap
Postby jonochap » Sun Jun 23, 2013 3:32 pm
Hold that thought, i seem the chief engineer checked for signs when we did...have just re screwed sump bolts again...fingers crossed :/
jonochap
Postby Muttley » Sun Jun 23, 2013 4:55 pm
Experience tells me that oil leaks are a long job if you keep doing them one at a time. Best to take engine out and replace all seals, also check oil pressure relief vave in cas its buggered and excess oil pressure is your problem. I dont mind helping you for tea and food, you supply the crane and the bits :wink: :)
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby jonochap » Mon Jun 24, 2013 12:55 am
Theres an oil pressure relief valve??? And a crane??? Thank you ever so much Mutts...will start planning. Hopefully we have done enough for the mo...mmm...crane...i think i need sleep!
jonochap
Postby jonochap » Thu Jun 27, 2013 7:28 am
Its all gonna be ok, i have the solution now
jonochap
Postby camper extraudinair » Sun Jul 07, 2013 12:44 pm
Hi J.C.
Just take out the engine change all the oilseals & gasketts
cambelt core plugs & forget the past.
Then we can get to meet up again in a nice location.
Looking forward to it soon.
best reguards C.E.
camper extraudinair
Postby jonochap » Sun Jul 07, 2013 7:39 pm
Hey CE...thats exactly where we are. Chief engineer directed the engine removal and gaskets and seal replacements. Yer man Robbie Cee stepped up big time with the kit...(due respect big man)
The only problem was 2 hours trying to get the bottom cog off broke the alloy oil seal cover. So we're hoping on a quick replacement from The Mutts. Was funny trying everyone we both know, thanks Mutts and Ralph and robbie and capt hook for answering the phone. Sadly couldnt get Diesel head which was a shame...Tim hope youre ok with the 28 missed calls :) :)
This was campernaut keeping us company at 11pm while we cleared down
jonochap
Postby Muttley » Sun Jul 07, 2013 8:44 pm
Will be getting the seal cover tomoz :wink:
Muttley
Postby jonochap » Mon Jul 08, 2013 1:54 am
Thanks Mutts :)
jonochap
cron
