My new Transit
My new Transit
Postby Lee J » Wed Sep 21, 2005 11:19 am
OK, technical questions.
2001 Y Transit 350 LWB (new shape)
1. My interior lights dont work & my dashboard clock isn't working too. Are these on the same fuse perhaps? Any help?
2. The numbers on my tripometer stopped turning. Both sets stopped at the same time. The speedo still works/illuminates etc just the numbers wont go around. Any clues?
3. How difficult is it to replace the rear interior lights with something more substantial like a 12 volt caravan light or summat?
that should keep you going for a bit. :D
Transit Van - Gonna cost me a marriage if I'm not careful.
Lee J
Postby MrMPuk » Wed Sep 21, 2005 11:27 am
For number 1 you need to check fuse number 10, this is probably the cause of number 2 as well.
Quite easy to replace the light in the back as it's only 2 wires as for replacing the front one, it would probably be quite hard to find something to fit the hole in the roof lining.
Postby Lee J » Wed Sep 21, 2005 11:32 am
OK, so fuse number 10 could be causing my tripometer fault too? My tripometer ISN'T digital does this make a difference?
Lee J
Postby MrMPuk » Wed Sep 21, 2005 11:36 am
Not digital okay, probably not the fuse. I'll have a look!
Postby MrMPuk » Wed Sep 21, 2005 11:40 am
It might be a fuse as it is electronic, so check all the fuses.
Has it worked at all since you've had it?
Postby MrMPuk » Wed Sep 21, 2005 11:41 am
Check to make sure the reset button isn't stuck in! I know it sounds silly but you never know!
Postby Lee J » Wed Sep 21, 2005 11:44 am
I dont think it has, I only noticed yesterday. I've had it into Ford to check it hasn't been tampered with and they say it's clean. the milages from services & MOT's match up etc
Lee J
Postby MrMPuk » Wed Sep 21, 2005 11:46 am
When you say you're not very techanical, how not techanical are you?
Postby Lee J » Wed Sep 21, 2005 11:59 am
Well I know my way around but I couldn't change a gearbox or timing belt.
Lee J
Postby MrMPuk » Wed Sep 21, 2005 12:12 pm
Well check those things and if still no luck let me know as there are a few other things to check.
Postby Lee J » Thu Sep 22, 2005 1:11 pm
OK people here's what happened...
I changed the fuse for the interior lights and hey presto the int.lights work a treat and so does the clock! Oh by the way it fuse number 60 in a 2001 new shape tranny. It's in the passenger side fuse box.
My radio is still playing up though. It wont work unless i slighty push the flip of piece in and then it requires a code (which I aint got and neither has the previous owner). I tried the factory standard code but it didnt work. It also is missing the ffwd and rwd buttons so I guess I'll just replace the whole radio for a newer one. It's currently got the Radio 3000 in. A Radio 4000 (cd) or a 4000 traffic (cd) should work shouldn't it?
Lee J
Postby MrMPuk » Thu Sep 22, 2005 1:46 pm
Glad to hear you fixed some of it, if you give me the stereo serial number I can give you the code and yes any of the ford range double din stereos will fit.
Postby Lee J » Thu Sep 22, 2005 2:17 pm
ok mate, thanks. I'm going to the caribbean tomorrow for 2 weeks, I'll sort this out when I get back.
Lee J
Postby MrMPuk » Thu Sep 22, 2005 2:19 pm
No worries.
my new transit
Postby Neil » Thu Sep 22, 2005 7:35 pm
mmmmm those dash faults sounds like someone may have been tamperin wi dials cant think y :lol: neil
Neil v6
Neil
Users browsing this forum: Jamesw1012
