Rover V8 to Transit MT75 Gearbox Adapter
Postby dieselhead123 » Thu Oct 17, 2013 6:54 pm
Just a few pics of the new project under development, an adapter plate to fit to the Rover V8 engine, alowing it to be installed directly to the Transit Mt75 transmission.
Following on from the success of the Essex V6 conversion, we are in the process of producing an adapter plate that will enable the Rover V8 engine to be installed to the Transit Mt75 gearbox.
This will be offered to forum members in a kit form, with full installation instructions being posted up in this thread.
The kit will consist of a steel CNC cut adapter plate and all the necessary hardware to secure this to the Rover V8 engine block.
A custom spigot bearing will also be included.
We intend to manufacture engine mountings to enable the existing Mk5 Transit chassis brackets and mounting rubbers to be retained, these will be supplied in addition to the adapter plates as a pair.
We have not yet installed the engine in our Mk5, the 'Surrogate Mother', so are unable to confirm as yet if bulkhead modifications will be required, but the adapter plate has been kept to the minimum possible thickness so as to provide as much space infront of the engine as possible.
Some pictures;
Finally, a shot inside the clutch housing;
The aim is to install the engine in the Surrogate Mother and provide detailed instructions on how to connect water hoses, electrics and exhausts so as to assist those installing the kit, naturally, any assistance/advice that can be offered by other forum members will be gladly recieved.
More to follow soon,
Re: Rover V8 to Transit MT75 Gearbox Adapter
Postby BigMonty » Thu Oct 17, 2013 7:26 pm
8) Practical application.
On lpg that will be as economical if not more than a 2.5di. It will pull a house down.
And it will sound 8) as fuk
BigMonty
Postby layalog » Sat Oct 19, 2013 2:23 pm
bloody xell tim looks like your have that in before me then lol :wink:
its not leaking, its just another tear
layalog
Postby limitedblack » Sat Oct 19, 2013 2:59 pm
Will it fit my mk7 Tim ? :lol:
Happy Easter
limitedblack
Postby dieselhead123 » Sat Oct 19, 2013 3:20 pm
limitedblack wrote:Will it fit my mk7 Tim ? :lol:
The developmemnt is intended to work with the Mk6/7 Mt75 as well, but only the RWD ones :lol:
Postby limitedblack » Sat Oct 19, 2013 4:27 pm
Bugger
Happy Easter
limitedblack
Postby dieselhead123 » Tue Oct 22, 2013 7:27 pm
A bit more messing done today.
Fitted the engine and adapter plate in Surrogate number 2, before it goes off to the Mk5 retirement home!
Here she is;
As we can see, it is a bit tight on the o/s bulkhead!
The oval hole you can see is where the clutch cable exits, there is room inside the cab to do a bit of bulkhead surgery to provide the necessary clearance.
The other side is better;
This is due to the fact the Ford offset the drive-train towards the right hand side of the van!
We ensured that the engine was placed so that the crankshaft line was exactly the same a Ford intended, this way there will be no undue stress placed on gearbox mountings and the prop shaft center bearing, you can clearly see the 'tool' used for all our conversions;
Here we see the 'void' where the right hand engine mounting will go;
The mounting will be a 'multi-piece' fabrication, the mounting attatchment point on the Rover block are not in the same plane!
Another view looking across the front of the engine;
No room for a rad at the moment though!
Postby captain hook » Fri Oct 25, 2013 9:16 pm
Early....P5/P6 Water Pump gives enough clearance to the Rad. :wink:
captain hook
Postby noah » Sat Oct 26, 2013 5:33 pm
goodwork fella
noah
Postby ake » Sat Oct 26, 2013 11:04 pm
If the Di is the best old school Diesel engine, then the Rover V8 is the best old school petrol :)
You can't consider yourself a petrol head until you have owned at least one of each ( preferably not fitted to a Mk 6) :D :D :D :lol:
Postby MinorMatt » Mon Oct 28, 2013 6:12 pm
Tims not a petrol head... he's a diesel head ;)
Postby dieselhead123 » Mon Oct 28, 2013 7:14 pm
MinorMatt wrote:Tims not a petrol head... he's a diesel head ;)
If only I could get hold of one of the 'Iceburg' development RV8 diesels, now that would be a cool engine in a Mk5 :lol:
Postby dieselhead123 » Mon Oct 28, 2013 7:26 pm
captain hook wrote:Early....P5/P6 Water Pump gives enough clearance to the Rad. :wink:
That's the information I have recieved, thanks for the confirmation there Captain 8)
We have now 'mocked up' the mountings, CAD files produced for the individual parts, minor differences for the Mk6 ones but trying to keep as many common parts as possible to keep the cost of the 'kit' to a minimum.
Pictures to follow, just been so busy in the shop the last week!
Postby ColinJack » Mon Oct 28, 2013 9:40 pm
dieselhead123 wrote:Pictures to follow, just been so busy in the shop the last week!
Going to be busy in the shop next week too (on my Mk3)! :lol:
1989 Mk3 Reimo Camper
1980 Mk2 Holdsworth Camper
ColinJack
Postby dieselhead123 » Tue Oct 29, 2013 8:45 am
Yes mate, all set for the next round of 'rust removal'.
