Leisure Battery
Postby AlanN » Fri Feb 09, 2007 5:53 pm
I cant get the link to open, but I have heard about them being used on the Winnebago.
youll have to tell me what i need to get,apart from another battery of course
Battery, two you mean!!! Go for it... Oh and battery boxes, that remnds me I must get some myself. :wink:
Postby MrMPuk » Fri Feb 09, 2007 6:10 pm
AlanN wrote:I cant get the link to open, but I have heard about them being used on the Winnebago.
Why would he need two? The van already has one!
Postby catdaddy » Fri Feb 09, 2007 6:36 pm
its gonna be dear enough without buying two batterys
catdaddy
Party Animal
Postby AlanN » Fri Feb 09, 2007 6:40 pm
I suppose it depends on what you want to run... I often park the van for the weekend and use the lights and a TV which I found run it down after one night, but with two, so far so good, although I havent been 3 days yet.
If its for amps etc then one larger one will do the job easily. :)
The engine has got 2 already :!: :!: :!:
Postby MrMPuk » Fri Feb 09, 2007 6:42 pm
If you get one decent leisure battery then it souldn't be a problem.
Postby catdaddy » Fri Feb 09, 2007 6:47 pm
one decent leisure battery it is then
catdaddy
Party Animal
Postby AlanN » Fri Feb 09, 2007 6:51 pm
Ive already done-in one leisure battery, my fault, kept using a cigar lighter on the curcit which buckled the plates. Can't afford another at the moment
How about one of these
http://cgi.ebay.co.uk/Solar-Panel-12V-14W-battery-charger-leisure-car-boat_W0QQitemZ320080574589QQihZ011QQcategoryZ41981QQrdZ1QQcmdZViewItem :D
Postby MrMPuk » Fri Feb 09, 2007 7:10 pm
You posted a link to one of them on the page before this.
Postby AlanN » Fri Feb 09, 2007 8:04 pm
So I did, I having such a good time on here, I can't keep up.
I won't post anymore :wink:
Postby transitgeoff » Fri Feb 09, 2007 10:24 pm
This is a topic i need to investigate further, i used a split charging relay in my van and the fridge drained the battery, when i started the van,i think my alternator (110 amp) shoved so much charge through the fuse went first(10amp) so then i put in 30 amp fuse and the relay melted :roll: how do you know what amp relay to fit and why did the split charge relay melt?? :?
transitgeoff
Postby Guy88 » Fri Feb 09, 2007 10:32 pm
I have been told to fit a relay the same as the alternator so for you would be 110a
Then even if all the charge whent through it it would still work and not burn the relay out. Id probably fit a 30a fuse in mine 8)
Sounds like the relay wernt rated high enough or was faulty inside :?
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AlanN » Fri Feb 09, 2007 11:08 pm
I have a 30A fuse in mine which does get a little hot at times and has to be replaced. Its the same old story, poor connections, causes high resistance = heat.
Postby gemini » Fri Feb 09, 2007 11:28 pm
gemini
Done some further research
Postby zaphod79 » Wed Feb 14, 2007 4:54 pm
Hoping to fit my leisure battery next week, if work doesn't get in the way! Found a reasonable relay at
http://www.autoelectricsupplies.co.uk/product/177 much cheaper than the £60 previous ally.
The landrover wire diagram was of great use, i have also found another diagram
http://www.kampenwagen.co.uk/images/Spl ... _relay.gif
I have also seen a cut off switch mentioned previously on this thread. Does any one know where abouts i would fit that, so that i could switch off each battery independently.
zaphod79
Postby OxtonyxO » Wed Feb 14, 2007 9:09 pm
dont forget to fuse both ends of the cable run as you have a battery at each end
OxtonyxO
cron
