cosworth in to a sw transit
Postby Luke » Wed Feb 14, 2007 8:17 pm
also flywheel and starter you get with a mk4 :lol:
would the pump be big enough :?: but yep you get the tank :D
Postby Gazza01 » Wed Feb 14, 2007 8:55 pm
would change to the cossie pump any way,,,, also what wrong with the fuel tank that comes with the transit??
is there anything else i might need to change why we on this subject ?
thanks
Gazza01
Postby OxtonyxO » Wed Feb 14, 2007 8:59 pm
easiest way would be to fit a low pressure pump and swirl pot like myself and guy have done
im running a cossie pump on my boa
OxtonyxO
Postby Guy88 » Wed Feb 14, 2007 9:30 pm
Problem is unless you get an EFI pinto there is no swirl pot built into the tank :( BUT you can change to a diesel tank which has a swirl pot and fit an external pump.
MK5 DOHC transits has the pump submerged in the tank. BUT if you fit a MK5 tank to a MK3/4 you need to cut about with the filler :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Gazza01 » Wed Feb 14, 2007 10:29 pm
ok goimg to get a diesel tank and fit the cossie pump ,, also change the rubber fuel lines as they wont handle the pressure
anything else 1 can think of??
thanks
Gazza01
Postby Luke » Wed Feb 14, 2007 11:29 pm
Guy88 wrote:BUT if you fit a MK5 tank to a MK3/4 you need to cut about with the filler :wink:
not all mk4s some have the mk5 filler point :wink:
Postby Guy88 » Wed Feb 14, 2007 11:50 pm
Fair enuf :roll:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Gazza01 » Sat Feb 17, 2007 10:25 pm
hi guys afterdays of looking for a good cheap petrol transit i have found NONE....
so looks like i have to get a deisel transit :
can you tell me anyone what the difference would be for this conversion
i no the engine mounts are different ,, can i just weld bolt on the right ones take the others of?????????
also what about the gearbox are they the same?? and the adapter plate dont come on a deisel so can i buy 1 of them from some where???
and the loom will that be harder to do as well???
can anyone else think of any other problems getting a diesel to do this project rather than a petrol transit???????
thanks for ur help cheers
Gazza01
Postby Luke » Sat Feb 17, 2007 10:35 pm
basically yes - you'll need all those bits off a petrol one :D as for the loom i dont think it will matter as you can just use the cossy engine loom anyway :D
personally if i was doing one i'd go for the mintest body wise i could afford :P rest is just bolt on bits :D
what mk have you seen 4 or 5 :?:
Postby Gazza01 » Sat Feb 17, 2007 10:45 pm
seen a n reg m8
so what will i need then mate and is it possible to add my own engine mounts??
the gearbox the same yer just need the plate?
also dont need to change the tank do i as its got a swirl pot as well
the prpo diff gearbox same as a petrol 1 yer???
Gazza01
Postby OxtonyxO » Sat Feb 17, 2007 10:47 pm
you will still need a swirl pot to feed the injection pump or find a 2.9 fuel tank
like this one
you then need a low pressure pump to suck from the tank to the swirl pot
or you can use a fuel sender unit from a dohc transit but it may noy supply enough fuel for the cossie depends on what power you are after
OxtonyxO
Postby Guy88 » Sat Feb 17, 2007 11:06 pm
I have to say the hardest bit of this conversion is the exhausts.
wiring is easy, mounts are easy on a MK3/4 pinto, adaptor plate will be on the pinto.
I reckon MK5 will be harder as you would need to source the bits separatly :wink:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Sat Feb 17, 2007 11:58 pm
Guy88 wrote:I have to say the hardest bit of this conversion is the exhausts.
yeah but he only has 1 to make guy :lol: and no manifold(s) :wink:
Postby rover » Sun Feb 18, 2007 11:58 am
At the risk of repeating myself (maybe this thread maybe another), if you have an external swirl pot you dont need one in the tank!!! Have a look on the turbosport forums, loads have done it with the original tanks!
All you need is a low pressure pump near the tank feeding the swirl pot in the engine bay, then the pipe comes from there to the injection pump(high pressure) and from there to the fuel rail and injectors, then the overflow/bypass goes straight back into the swirl pot and doesnt need to go back to the tank, the swirl pot is used purely to act as a continually topped up mini fuel tank :D
Is that any clearer?
Rover.
rover
Postby Gazza01 » Sun Feb 18, 2007 12:59 pm
ok thanks it helps
you say look at turbo sports forums yer thanks i will do cheers
Gazza01
