2.5Di fuel pump.. smoke screw??!
Postby Boycie » Wed Sep 28, 2005 6:45 pm
Howdy!!!
Well my Transit is still plodding along nicely, carting about pretty much anything I need :D
I must say though, I'm still using mucho fuel compared to my last vehicle!
What I would like to know is, can I adjust the pump to inject less fuel (and make it more economic). I know people used to turn up the fuelling to get a bit more ooomph on older diesels.
Anyone know what to do? It's a '94 SWB with the 'nanna engine.
:D
Boycie
Postby MrMPuk » Wed Sep 28, 2005 6:50 pm
How many miles are you getting out of a tank and what kind of driving are you doing?
Postby Boycie » Wed Sep 28, 2005 8:00 pm
Well I'm doing mainly A-road runs, normally at a steady 50-60ish. Also often with a very light load (a cylinder head or couple of tyres etc).
I never fill the tank full (don't know why...) but always put in £20. That gives me halfway between the 1/4 and 1/2 mark on the gauge.
That gets me 120 miles if I'm lucky, which works out at 26mpg.
A bit low?
Boycie
Postby MrMPuk » Wed Sep 28, 2005 8:06 pm
Yeah that sounds about right. As for messing with the pump think you might be best off leaving that well alone!
Postby Boycie » Wed Sep 28, 2005 8:30 pm
Yeah I suppose I would do more harm than good...!
I'm unfortunately used to an Astravan TD (Isuzu) that did a genuine 45mpg... 240 miles to £20.
I think the RWD, slab-like aerodynamics and weight must kill a Transits economy!
Boycie
Postby MrMPuk » Wed Sep 28, 2005 8:50 pm
Plus of course there is a bit of a difference in weight and engine size!
Postby Boycie » Wed Sep 28, 2005 9:15 pm
Yeah, I think I'm expecting a bit much!!
I was thinking the lack of a turbo would make a bit of a diffence. Regardless, I think a full service is due anyway :)
Boycie
Postby Luke » Wed Sep 28, 2005 10:06 pm
Boyce is yours the 6 stud wheel type? what ratio is your back axle? - have a look there should be a little ally tag on it with something like 4.5:1
you may be able to fit a higher ratio axle that will improve fuel consumption!! :D
Postby Boycie » Thu Sep 29, 2005 9:13 am
Luke wrote:Boyce is yours the 6 stud wheel type? what ratio is your back axle? - have a look there should be a little ally tag on it with something like 4.5:1
Yeah it is Luke,
I'll check out the ratio!!
Can you change the diff seperately, by pulling the halfshafts out?
Boycie
Postby Boycie » Mon Oct 03, 2005 8:12 pm
Hey Luke!
I found the tag under one of the cover bolts on the rear diff!
It reads like this....
92 VB LAD
463 T51A
How on earth do you decifer anything from that?!
Cheers,
Boyce. :D
Boycie
Postby Luke » Mon Oct 03, 2005 8:16 pm
Boycie wrote:Hey Luke!
92 VB LAD
463 T51A
Cheers,
Boyce. :D
4.63:1 i guess :?
now madmark is there a higher ratio available?
diff ratio
Postby john leeman » Tue Oct 04, 2005 8:30 pm
yeh 3.91 in early dis b reg onwards 80 100 & 120 swb vans
35 years of driving,repairing,sleeping in transit's lovin every minute.
john leeman
Postby transitgeoff » Tue Oct 04, 2005 9:00 pm
4.63 is about the highest high speed axle your gonna find from 1992 onwards most you look at are 5.14 meaning 5.14 turns of the prop to one turn of the wheel, so the 4.63 only has to turn its prop 4.63 times to turn the wheel once all that meaning its better on motorways but around town 5.14 is better. :D broke hundreds of Tranys 1992 and newer and have never seen any axle starting with a 3. anything :?
transitgeoff
Postby Boycie » Wed Oct 05, 2005 8:33 am
Cheers guys :D
It also whines like crazy.... it drowns out the (very well insulated) engine noise at some speeds!
Is it an 'ok' job to replace?
Do I have to remove the whole axle? Or can I pull the shafts out and slide the diff out of the casing?
Could I fit another ratio and would it be worth it?!!!
Sorry for all the q's :oops:
Boycie
Postby Luke » Wed Oct 05, 2005 10:54 am
Not sure if an earlier 3.91 diff will fit in your axle a 3.91 will be a twin wheeler axle!! mabe the diff is the same but im not sure!! :?
if yours was a 5.14 you could go to a 4.63 easy but as yours is the 4.63 according to geoff thats the best your gonna get as standard!! :(
as for the diff swap ive never done it on one of those but im sure someone on here will have!!! :)
