Fridge 12/240v and gas
Postby tlsjk » Sat Feb 01, 2014 12:56 pm
I am planning to get a 3way fridge for my van (mk5 swb low roof) I am only going to run it on 12/240v NOT GAS so do I need to put a vent in the side of my van:?:?:?:?
Wiggers Welding & Car Repairs 07931230167
Cargo Van, 80 Series, Diesel 2.5 (70PS)now banana (76PS), 5-Speed Manual - MT75, Axle Ratio:4.56
IF ITS NOT FORD, SCRAP IT!!!
tlsjk
Re: Fridge 12/240v and gas
Postby limitedblack » Sat Feb 01, 2014 1:58 pm
Well it will generate some heat, plus I guess it's for summer use, so if it was me I'd have a vent, but only for the heat.
Happy Easter
limitedblack
Postby ake » Sat Feb 01, 2014 2:14 pm
limitedblack wrote:Well it will generate some heat, plus I guess it's for summer use, so if it was me I'd have a vent, but only for the heat.
As said, you still require the vents to allow to circulate over the back of the fridge
Postby matt86_wd2 » Sat Feb 01, 2014 3:37 pm
i wouldnt go for a 3 way in your case , as a 3 way fridge is not too efficient on 12v .
I would go for a waeco compressor fridge which is 12v and dont bother to buy the 240 transformer as when your plugged into electric hook up have your battery charger on , so will be charging the batteries and then powering the fridge .
this is what i will be doing along with having a solar panel
matt
matt86_wd2
Postby tlsjk » Sat Feb 01, 2014 4:31 pm
Thanks for the replys, might also be worth pointing out that we are not sleeping in the van, we have a tent as it would be a squeeze trying to sleep 4 adults and 3 kids in a swb lol. Just want a fridge for milk and a few other bits
tlsjk
Postby bobdragon12 » Sat Feb 01, 2014 7:10 pm
In that case go for a compressor fridge , I have a none compressor 3 way as compressors are noisy but the none compressor only drop below a certain range of ambient temperature and when we were in France last year and it was up in the high 20's the fridge struggled to keep stuff cool
MK2 LHD coachbuilt Camper 2.5TDI
bobdragon12
Postby matt86_wd2 » Sun Feb 02, 2014 7:10 pm
i cant see how you had troubles with a waeco compressor type they get brilliant reviews much better than the others .
do a search on tinternet and you will soon find them , matt
Ps just read back and noticed was not a compressor type oops :oops:
matt86_wd2
Postby tlsjk » Sun Feb 02, 2014 8:10 pm
I would like a waeco but I dont want to spend that sort of money on something that is going to be used a few times a year
tlsjk
Postby matt86_wd2 » Sun Feb 02, 2014 8:12 pm
ah i see , well in that case if only using a few times a year i would go for a 3 way and cut the vents .
matt
matt86_wd2
Postby ColinJack » Sun Feb 02, 2014 10:31 pm
tlsjk wrote:Thanks for the replys, might also be worth pointing out that we are not sleeping in the van, we have a tent as it would be a squeeze trying to sleep 4 adults and 3 kids in a swb lol. Just want a fridge for milk and a few other bits
Like beer & wine! :lol:
1989 Mk3 Reimo Camper
1980 Mk2 Holdsworth Camper
ColinJack
Postby ColinJack » Sun Feb 02, 2014 10:32 pm
If you are just going to put milk and bits in it then just get a 12v cooler box?
http://www.gooutdoors.co.uk/expert-advice/coolboxes-and-fridges-guide
ColinJack
Postby matt86_wd2 » Sun Feb 02, 2014 10:42 pm
or a waeco coolbox have a google on it and loads come up .
matt
matt86_wd2
Postby ColinJack » Sun Feb 02, 2014 10:48 pm
matt86_wd2 wrote:or a waeco coolbox have a google on it and loads come up .
matt
Exactly what I was saying ... get a coolbox e.g.
http://www.amazon.co.uk/Waeco-Mobicool- ... d_sxp_f_pt
ColinJack
Postby matt86_wd2 » Sun Feb 02, 2014 10:55 pm
thats a cheaper smaller one , but if spend around £140 ish can get one a fair bit bigger .
matt
matt86_wd2
Postby ColinJack » Sun Feb 02, 2014 10:58 pm
matt86_wd2 wrote:thats a cheaper smaller one , but if spend around £140 ish can get one a fair bit bigger .
matt
Way to go I reckon ... can even take it out and put it in the tent when you want.
ColinJack
